Quench - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-27-2003, 06:03 PM
The Vandal's Avatar
Engine Tech Addict
Post Quench
I'm putting together a 350 short block and after the 3rd piston I decide to take a look at deck height. I measure .027 in the hole on all 3. The pistons are domes so compression is not really an issue but how do I get the quench that I need? A typical gasket gets me around .060 but isn't that too much? Is there a really thin gasket? PLEASE don't tell me that the block needs to be decked!!! Thanks all,
The Vandal
Old 02-27-2003, 06:25 PM
Post
The Fel Pro 1094 gasket has a compressed thickness of .015". This gasket also has a smaller bore than a lot of gaskets (4.100") for slightly more compression.
Old 02-27-2003, 06:40 PM
NorthStar's Avatar
Post
Yes there are thin gaskets that are about .020 thick stamped steel from Felpro part# HS7733SH2 for the set.
Old 02-27-2003, 07:39 PM
F-1Rodder's Avatar
Post
You are using domed pistons? Where is the quench area? What compression are you targeting? You need to hit a quench of .045 or less.
Old 02-28-2003, 04:10 AM
The Vandal's Avatar
Engine Tech Addict
Post
The quench area is on the intake manifold side of the piston and I'm looking for 11.5 to 12:1.
The Vandal
Old 02-28-2003, 11:38 AM
F-1Rodder's Avatar
Post
Honestly, I cannot speak with authority on this, you need to do some research but here is what I suspect. First, you know you won't be able to run pump gas with a motor with that much compression. Second, the quench is meant to induce a swirl effect in the pocket that will not support detonation. It is easy to do with a flat or D cup piston, but I don't know about a domed piston. Most of these were used in conjuction with leaded gas back in the 60's. Maybe the dome creates this effect, but I am not sure. You need to get the quench down below .045 however. I did zero deck my block and used a .025 gasket. It works very well for me.
Old 03-01-2003, 05:39 PM
1BAD80's Avatar
The Smell of Nitro in the morn
Last wiki edit: How to adjust valves Last photo:
Wiki Edits: 2
Post
I agree with F-1Rodder on the type of pistons to use, if you want that high of compression I recommend aluminum heads. I'm running 11.5:1 with flat tops without any problem.
Luv the smell of NITRO in the morning.
Old 03-02-2003, 10:03 AM
The Vandal's Avatar
Engine Tech Addict
Post
I'd love to throw $1000 at a set of heads but it's just not going to happen. I'm using a set a fully ported 492's that I snagged for $200. They fit into my budget and will have to do. Thanks for the help guys, I'm going to go with the .015 Fel-Pro's as my machine shop seconds the recommendation providing I don't run nitrous. They say the thin gaskets tend to go away between the cylinders with high cylinder pressures (just thought I'd pass that along).
The Vandal
