Question - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-27-2006, 02:54 PM
Question
This may seem like a dumb question, but I was wondering, what is the point of having a large amount of carbs on an engine, when the chambers can only have a ceratin compression ratio.
This question may not make any sense, but I hope someone can aswer it.
Old 11-27-2006, 03:00 PM
Henry Highrise's Avatar
Lost in the 60's
Wiki Edits: 4
Your question does not make any sense to me. Can you re word it so I can understand it?
Old 11-27-2006, 05:15 PM
powerrodsmike's Avatar
Wiki Edits: 161
I KNOW THAT ONE Because too many of anything is just enough. Hahahahaha, just kidding
Here is the formula the BIG FAMOUS car builders don't want YOU to know.
A aE/A Ia=X Ia (preferred ratio)
1.25
A= area
aE= above engine
Ia=induction apparati
Kewl, Huh?
later, mikey
BE different....ACT normal.
Old 11-27-2006, 05:24 PM
30desoto's Avatar
Dodge ain't all bad
Alright Mikey,,,share the brownies, you even lost me on this on, but then again I am old and now need a drink
30dee
Old 11-27-2006, 05:32 PM
poncho62's Avatar
Wiki Edits: 5
It's not the just compression ratio that you need to be considering....its more the amount of flow an engine needs. There is a formula for that, which considers cubic inches, RPM etc. Simply put, the more gas you can make an engine burn, the more power it makes.........but, you must be capable of burning all that gas.
Ontario Rodders
Old 11-27-2006, 05:58 PM
Lost in the 60's
Wiki Edits: 4
Right...good flowing heads and a good cam are what you need to use high cfm carbs.
Old 11-27-2006, 06:00 PM
Lost in the 60's
Wiki Edits: 4
One reason for wanting to use multiple carbs on streetrods is for looks. A old Buick Nail Head with 6 deuces looks good and just reeks hot rod.
Old 11-28-2006, 01:33 PM
Thats what I was getting at (or at least trying to)
Old 11-28-2006, 02:58 PM
stea's Avatar
It's definately for the COOL factor. I love multi carb set ups and plan to change my Deamon for a 3x2 setup. I know more than likely it wont perform as well but it sure will look the part.
Old 11-28-2006, 03:20 PM
Lost in the 60's
Wiki Edits: 4
I have a three deuce set up...tri-power style. The center carb is the primary...it is the only carb with idle circuits and air/fuel mixture adjustments. The front and rear carbs are secondary carbs and with the linkage I am using the kick in like a four barrel. This is a good way to run 3 deuces..... no big tuning and syncronization issues.
Old 11-28-2006, 03:30 PM
ChevelleSS_LS6's Avatar
Jeep XJ and a Javelin
Last wiki edit: Compression test
Last journal entry: August 9, part III
Wiki Edits: 7
On musclecar era engines, especially small blocks, a crossram intake looks wicked, like AMC's Group 19 intake (used in trans-am Javelins) and the crossram intake on the DZ302.
I think one would look good in my Grandpa's Crosley. It's been sitting in the pole barn for ages and ages.
Old 11-28-2006, 04:19 PM
Wiki Edits: 161
SEE, SEE!! two perfect examples to verify the accuracy of mikey's Algeebrayic equation.
Area on top of the motor needed to be filled by induction apparatus divided by 1.25 divided by area occupied by carburator= how many carbs required to cover motor without looking like a cartoon
later, mikey
Old 11-28-2006, 10:23 PM
MI2600's Avatar
Member# 3287
Mike,
Is that a speed secret?
Old 11-28-2006, 10:56 PM
Wiki Edits: 161
Originally Posted by MI2600
Mike,
Not any more, I posted it here , didn't I?
Question about vehical weight and engine question Thuggishruggish3000 Engine 12 03-24-2011 05:22 AM
question about a previouse question elrod1030 Engine 6 03-10-2010 07:35 AM
383 stroker 73monte Engine 10 12-05-2009 08:02 PM
Switching to 200R Tranny question Gundarak Transmission - Rearend 4 12-05-2003 08:00 PM
nitrous 69BiRd Engine 2 11-28-2003 10:33 PM
