Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Question on 1996 Lumina
Old 07-09-2012, 05:20 PM
LATECH's Avatar
LATECH LATECH is offline
Last journal entry: GTO Reproduction Hood
Seems the power and ground circuits are tied together in paralell on the cam and crank sensor.
It sounds like a crank sensor to me also. I think the fault detection strategy on those old 3.4 is kinda faulty itself.
Your correct in assuming the cam sensor failing would not cause a no start no run situation also.That would be a crank sensor.
Put in the crank sensor.
Fact is stranger than Fiction
The Following User Says Thank You to LATECH For This Useful Post:
DoubleVision (07-09-2012)
