Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Question on 1996 Lumina
Old 07-09-2012, 07:06 PM
T-bucket23's Avatar
T-bucket23 T-bucket23 is offline
Wiki Edits: 26
LA you just jogged something in my memory. I had one with the sensor on the back of the block near the fire wall and the clip that held the wire died with age. The wire was loose and it was shorting out on the exhaust manifold. Found a bare melted wire after tracing the harness. It was the wire that went right from the coil pack down to the crank sensor. It was a little later setup that actually used the 2 crank sensors but it is worth looking at
Chet
