question on 318 magnum engine in street rod - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-16-2008, 05:37 PM
I have a chance to buy a 2002 318 magnum engine and 46re trans.I would like to put it in my 1934 plymouth coupe.Has anyone ever installed one in a street rod and did you wire it up yourself?I know i should get a 5.7 hemi but my budget is low.I am looking for fuel mileage and good performance.I would think the 318 should get low 20s on the highway with the right gearing.My car has a 1969 340 in it now that doesnt run.I had 340 cars in the 70s and don't remember them getting very good economy.Street and Performance said they could make a harness but told me to buy the 5.7 I also thought about putting a carb on the 318 so i didn't have to use the injection system but i don't believe that would be any better.Thanks Dave
Old 06-16-2008, 09:55 PM
F&J F&J is offline
Last journal entry: 32 Ford cabriolet conversion/windshield
I don't have an answer to your main question, sorry. But, if that is a "real" 69 340, it is worth a few bucks, as well as the stock hipo exh manifolds. 69 is a real hot collector year. So you maybe can help finance your build.
The early 340s were bad on gas for one reason...they were set up for pure muscle. Hi compression, good cam, and mostly 3.91 or 3.55 gears. 73 & up were detuned and had lower gears.
I would not carb a injected motor if you are going for mpg.
Keep checking the web for wiring companies, someone may make one. Or, find a talented friend that can find the stamina to peel & ID the donor car wires in the harness...it's been done many times by guys using those computer motors as soon as they came out.
Old 06-25-2008, 08:21 PM
wedgehead63's Avatar
Last journal entry: New Attitude
I am in the same boat. I have a 35 plymouth pj sedan. I want the 5.7, but by the time you add all that is needed, OMG. I have two 318 magnum motors complete and am planning to rob a harness from a junker. Lack of money makes you brave!
Old 06-25-2008, 10:48 PM
lemondana's Avatar
318 Magnum install
To both of you: Mopar Performance or the new Direct connection has the complete wiring harnesses and stuff you need for either the 318-360 Magnum or the 5.7 Hemi, although pricy I'm sure. Go to your Chrysler dealer that handles MP stuff and they should get you the bulletins you need. Myron
Old 06-27-2008, 12:16 AM
Hopefully you are getting the OD trans too. That's about 4 mpg.
I have done several Fords and Chevies and the basic wiring is simple.
You will need a schematic for the donor car to find which wire goes where.
Simply, the computer gets a constant + and - for memory
The fuel pump can be wired direct/relay or through the computer for start cycling. Don't forget the inertia switch for wrecks.
The heated oxygen sensors need relays.
No heavy loads directly through the key switch.
The 3 computer trigger circuits off the "Key" are
start
run
start and run
So really, the only things hooked to the old harness/key is the 3 power wires to tell the computer what is happening when.
Lay out the harness and see what you need and don't, and relocate components as necessary. PATIENCE
ABSOLUTELY= every spliced wire must be soldered and covered in glue filled heat shrink tubing. Or you will have a failure some time soon.
simple, take your time and you will be well rewarded.
the history of chevy v8's savman1 Hotrodders' Lounge 43 03-02-2012 07:57 PM
Valve Lash adjustment hiball Engine 36 05-11-2009 11:12 AM
6in rods in a 327? backyard71nova Engine 5 09-16-2007 08:21 PM
350 head question for street engine on pump gas buzz1961 Engine 2 07-13-2006 11:54 PM
not a rod question but an engine swap question for a daily driver.. DeathByGreaser Hotrodders' Lounge 2 01-22-2004 11:59 PM
