Question on 49 chevy truck frame - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-12-2006, 12:35 PM
Am wondering what is the difference in the frame on the 47-54 chevy truck 1/2 and 3/4 ton frames?
Am thinking of installing a Mustang II IFS system in my 49 3/4 ton truck and some the catalogs list it as 1/2 ton with no mention of 3/4. This there some difference in the rail spacing as to why I cant install a IFS system in a 3/4?
I would like to keep the long bed look, so if push comes to shove I would need to find a 1/2 ton frame and extended it. Thanks...Eric
Old 08-12-2006, 04:11 PM
Eric, I don't believe there is any difference from the back of the cab forward. My truck was originally a 3/4 ton. I switched to a 1/2 ton frame swapping over all my parts including axles to the new frame. I think the only difference is the length of th drive shaft (two piece actually).
Old 08-13-2006, 10:18 AM
home brew's Avatar
Last wiki edit: Body and exterior tips Last photo:
sevt_chevelle - Here is a link to the specs of different AD chevy trucks:
http://chevy.tocmp.com/chevyresto/5055.htm
Old 08-13-2006, 12:54 PM
Homebrew, thanks for the link,
I was pretty sure that the cab forward was the same. I was thinking of using Chassis Engineering bolt in IFS system but they list it as 1/2 ton only.
I guess I need to email CE and ask them whats up.
Old 08-13-2006, 01:42 PM
49 Chev Truck Frame 3/4 ton
Good link to the specification section for the 49's. I've installed a Fatman MII front end on my 3/4 ton without any problems. The difference in the frames seems to start just about at the back of the cab to the rear. Basically the frame rails are parallel on the 3/4 ton and on the 1/2 ton the widen out from the cab back. In the beginning I thought they were the same so I now have a set of frame boxing plates that fit a AD 1/2 ton. Also when looking for a rear end setup I talked to Chassis Eng and finally got out of them that the rear suspension kit they make would n ot work.
LD
Just placed the SBC and tranny in the frame yesterday!! Body to soda blast next week!
63 chevy truck cab on a 67 GMC frame? Ranman1822 Body - Exterior 1 07-16-2006 05:17 PM
1979 Chevy Truck Interior question hiball Interior 3 12-06-2005 09:27 AM
Chevy AD Truck Wiper Motor Question bigfred1958 Interior 1 11-12-2004 04:49 PM
Air Suspension on 49 Chevy Truck BigMac Suspension - Brakes - Steering 7 10-28-2003 12:51 PM
Body & Frame question ruiner808 General Rodding Tech 7 09-14-2003 05:54 AM
