Question on 4x4 conversion - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-14-2009, 05:21 PM
d&c repairs it all's Avatar
Still working on 4x4 conversion on my 69 truck. Need a good exploded view of the suspension of both a 1969 1/2 ton and a 1974 3/4 ton suspension system. We welded the front clip from a 3/4 ton onto the 1/2 ton frame, so essentially have a 3/4 ton frame where suspension is concerned. The next problem is the radius arms and drop arm brackets. Will I need different radius arms or no? thanks for advice, and also any links you know of that have exploded view diagrams of this stuff.
thanks, jimmy, cathy, and everybody else working on this project
Old 02-14-2009, 11:57 PM
Radius arms makes me guess you are dealing with a ford
Old 02-15-2009, 12:02 PM
reply on conversion
Yes, sorry, it's a Ford. Also have a second question, do you or any body else out there have any preferences to places that make reliable ring and pinion sets? or know where not to order them from? Thanks for your help.
Carburetor Conversion Question Gpfalzbot Engine 1 03-23-2008 06:06 PM
BBC Roller Cam Conversion - Endplay Control Question leejoy Engine 1 02-09-2008 08:03 PM
a quick 4x4 question jesse01 Transmission - Rearend 4 04-11-2006 04:48 PM
305 to 350 conversion in 84 Blazer 4x4 wed68 Engine 7 02-15-2005 12:07 AM
s10 4x4 v8 conversion sweethome18 Hotrodders' Lounge 6 10-14-2002 07:55 PM
