Question on 70 GTO door weatherstrip - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-05-2012, 02:33 PM
Guys,
The weatherstripping on the door of the 70 GTO I recently purchased seems like it needs to be glued down. It is just flapping in the breeze. Can anyone tell me how this portion of the weatherstrip was attached from the factory? Please see the pics I've attached.
Thanks,
Mike
P.S. It looks like it should extend to just slightly under the door panel. Is this correct?
Mike
Name:	door jam weatherstrip B.jpg
ID:	66569   Click image for larger version
Name:	Door jamb weatherstrip.jpg
Old 07-05-2012, 03:19 PM
painted jester's Avatar
TAKE A KID TO A CAR SHOW
Last journal entry: Wifes 79 comeing together!
Mike: you should have received black plastic push in tabs with round heads and a toothed shaft the heads are about 1/4 to 3/8s inch diameter and the shaft about 3/8 long that go into holes in the rubber sometimes very hard to see and attach the strip to the door that should have small holes, some stripping is attached with small screws in that area but it is advisable to use weather strip adhesive sparingly (dont gob it on) in conjunction with the tabs or screws all the way around the door !
And yes some extend just under the panel!
Jester
Old 07-06-2012, 10:51 AM
The outer half of the weatherstripping has the tabs and screws, but the inner half, toward the door panel has none, and it doesn't have any holes in the door (or weatherstrip) to put them. See additional pics attached. I'm guessing it just get's glued into place and that it get's tucked under the edge of the door panel, right?
Mike
Name:	door jam weatherstrip C.jpg
ID:	66591   Click image for larger version
Name:	door jam weatherstrip D.jpg
Old 07-06-2012, 12:19 PM
Mike
Yes
Chris
Old 07-06-2012, 01:33 PM
Sweet, thanks!
Mike
Old 07-06-2012, 07:32 PM
DanTwoLakes's Avatar
Wiki Edits: 22
I'd like to interject something here. The only reason there is weatherstripping is to seal a door or window from water. Roll the window up, close the door, and see where the weatherstripping contacts the window or door jamb to keep the water out. That will tell you where to attach the weatherstripping.
ls1 gto question doubleD_white_t'a Hotrodding Basics 19 01-20-2009 09:56 PM
1964 gto tranny question pi71 Transmission - Rearend 3 10-17-2008 03:35 PM
GTO or LEMANS?That is the question 68lemans Hotrodding Basics 17 12-04-2007 04:12 PM
Wrecks to Riches GTO Blue Paint Question David Morris Introduce Yourself 3 05-14-2006 10:41 PM
Next gen GTO is a 4 door- in a good way. ChevelleSS_LS6 Hotrodders' Lounge 13 08-12-2005 07:05 AM
