Question about .015 head gaskets - FelPro 1094 - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-30-2006, 04:44 PM
Hello, I'm a new member. I have a 1980 Corvette with a 3.73 rear and the motor on a stand.
I want to increase the compression on my small block from approximately 9:1 to 9:5 or more to accommodate a Summit 224/234 .465/.488 cam that I've purchased. I'd like to use FelPro 1094 which is a .015 as opposed to the .041 that I already have. Are there any considerations or compromises to take into account when using a thinner compressed head gasket? It's seems obvious that .015 is much lower than the standard size head gaskets out there so that's why I'm questioning.
My engine is a .030 over 350 with 041 .194/64cc heads. The pistons are flat cast aluminum with 4 valve reliefs. I tried to cc the cylinder volume at 1/2" and made a mess, but I came up with about 9.1 to 9.3 compression. I measured the piston in the hole and they're down there pretty far - about .050. I really want to try to put this top end together myself and learn how to do this in the process. This is a somewhat low-buck project so I'm not installing new pistons for higher compression. Thanks very much for any input.
Old 03-30-2006, 04:52 PM
King of my Man-cave.
As long as the block and heads are FLAT, you should have no problems with the thinner gaskets. If your heads have not been milled, now would be a good time to do so. The gaskets come with a sealant already on them so don't use any additional sealer. BTW, they will also improve your quench situation so it's a win-win situation.
tom
Old 03-30-2006, 05:08 PM
Thanks Tom, I appreciate the help. I'll check on the heads and block with my machine shop tomorrow. Thanks again!
flat head question mercmama Engine 7 03-29-2005 07:59 PM
What head gaskets do I need Bryce Engine 9 03-01-2005 02:45 AM
head gaskets for aluminum heads bpnoble Engine 5 12-04-2004 06:27 PM
SBC Head gaskets.....which ones? TheZaZ Engine 6 03-15-2003 10:36 AM
Head Gaskets HotRodS10 Engine 4 08-13-2002 05:30 PM
