Question about 350 - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-11-2005, 07:49 PM
chianesi's Avatar
Never Give Up
Question about 350
Are all 350's cast the same. I have a 78 corvette with a tired motor, I want to put another motor in while I rebuild the original one. Will any 350 fit?
Old 10-11-2005, 08:04 PM
Yes, but check if the new block has a provision for the clutch ball stud, if it is standard shift.
One other thing, later blocks have roller cams and are not direct bolt ins if you are looking to use parts from the '78.
Old 10-14-2005, 06:10 AM
chianesi's Avatar
Never Give Up
much appreciated, thanks!
Old 10-14-2005, 06:52 AM
RCastle's Avatar
Come Home Safe Soldier
Last journal entry: Headers
There are differences in 350 engines.After 85,they had a one piece rear main seal,which is a huge plus at preventing oil leaks that are so common there.Dimesion wise,they are the same though. Also depending on the era 350 you get,you can get some horrible flowing smog heads. Also the LT1 and up blocks are completly different,that was the beginning of a new dawn for Chevy SBC as we know them.Anything up until92 is the same,with the exception of the 86 up blocks,which have the one piece,plus the dipstick for the oil has been relocated to the passengers side.
Distributor Tuning and Theory - Part 1 Rick WI Engine 35 04-26-2011 12:38 AM
Distributor Question - 1985 305 and 1975 350 Fragzem Electrical 3 10-28-2003 10:07 PM
350 motor question bubb rubb Engine 4 03-25-2003 04:45 PM
75 Jag with Corvette 350 exhaust question Jag Daddy Engine 4 03-12-2003 03:30 AM
91-5.7 350 question Dan Augustine Engine 8 02-02-2002 06:32 AM
