question about ac compressor - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-04-2003, 01:26 PM
simple question: when the ac is on, should the ac compressor be constantly running (on an 95 escort)? I keep hearing a slight popping sound from some type of transistor, then the ac compressor shuts down, then back on a again in another few seconds?
Does it sound like the compressor going bad?
Old 11-04-2003, 01:38 PM
johnsongrass1's Avatar
Race it, Don't rice it!
The compressor must cycle on and off to maintain the correct amount of system pressure. You will see the clutch turn on and off.
Old 11-04-2003, 06:11 PM
302 Z28's Avatar
It's possible what you are hearing is the low pressure cut off switch. If your compressor is low on freon it will cycle continuously and rapidly.
Vince
