question about arp rod bolts - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-25-2012, 11:50 AM
I know the 350 arp rod bolts are longer than 400's, but will 350 rod bolts work in 400 rods, or are they too long all together? A little back story: A buddy of mine is building a short rod 383 for his s10, he went to our local speed shop and bought a set of ARP rod bolts, and bought a set of 400 rods from me. They don't have a set for a 400, and he can't take them back now, so I was wondering if he can use them, he already has the crank, rods, and pistons.
Old 07-25-2012, 01:13 PM
SSedan64's Avatar
Not gonna work without Mods >> 400-CID Connecting Rod Bolt
Old 07-25-2012, 02:18 PM
what would the mods consist of? Would he just be better off selling them and order a set for a 400? thanks
Old 07-26-2012, 10:21 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Better off getting the right ones IMO.
Old 07-26-2012, 10:35 AM
The standard lenght rod bolt is a bit over an eighth inch longer than the 400 bolt. The 400 upper shank lowers the bolt by that amount. This will put more of the unthreaded length into the cap's bolt bore and will hang the threaded end .140 inch further toward the pan rail. I don't have a 400 rod handy to compare but the problem areas could be not enough thread to secure the nut properly plus I'd expect the extra bolt length will interfer with the pan rail as this clearance on the 400 is already tight.
You can always mock this with the ARPs in the 400 rod and check it out since he can't take the bolts back anyway so putting a few scratches in their finish isn't going to result in not being able to return them.
Bogie
ARP Rod bolts - how much better over stock? Mad Maggot Engine 22 05-05-2013 08:19 AM
putting in arp rod bolts in bbc bbc68 Engine 3 05-28-2012 07:25 PM
Ok torqued rod bolts todaydid what arp said to do Will I be safe? eric32 Engine 6 05-29-2009 02:57 PM
Installing arp rod bolts Eric327 Engine 4 03-10-2007 05:50 AM
Torque spec question ARP bolts surfshark Engine 3 10-14-2006 10:15 PM
