Question about astro van transmission??? - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-26-2004, 01:19 PM
Robbie's Avatar
Last journal entry: nova
I have an 87 astro van with a v6 engine and automatic transmissiom with over drive..Im fixing to change the fluid and filter and was wondering what transmission fluid would be the best for it. it has alot of miles on it and the fluid is almost black..
it doesent slip . i got to pull it out this weekend to replace the front seal. its leaking...
thanks robbie
Old 05-26-2004, 02:46 PM
stepside454's Avatar
from my experiance, if the fluid is that dirty, dont change it, the new fluid will wash whats left of the clutches off & itll be done for sure, chances are it needs to be rebuilt, if you leave the old fluid in youll probly get a little more life out of it. new fluid will nearly gaurantee its death early
Old 05-27-2004, 01:50 PM
I'd say use Dexron or Mercon, but it probably says what to use on the dipstick, right above the checking mark.
