Question about BBC (396) head - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-12-2008, 04:10 PM
Last journal entry: Bringing home the 401 Nailhead
This is a picture of the drivers side head looking from the front. Can anyone tell me if the indicated plug opens to the water jacket? It looks like it is 3/4 NPT but will have to remove to measure for sure.
Old 03-12-2008, 04:37 PM
Barry.M's Avatar
Old Phart
Last wiki edit: How to identify a Ford V8
Last journal entry: 27 T Roadster project-For Sale
Wiki Edits: 3
Yes it does go into the water jacket. Unless you've got a specific reason to open it up......leave it alone.
Old 03-13-2008, 05:11 AM
Too long to explain but I am installing a second radiator. Looking for a place to tap in for a supply hose. The intake has a 1/2 npt but thought this might be better since it looks like 3/4 npt.
Old 03-13-2008, 08:31 AM
11echo's Avatar
Old Guys Rule!...EVERYTHING!
"IF" you need a place or tap in for a new radiator, look at tie-in to the heater connections!
I'd be interested in hearing more about this "second" radiator your planning!!???
Old 03-13-2008, 09:39 AM
OK try to make this a short story. We have a 39 willys. As I understand it the factory used leftover 38 front fenders and hoods for the pickups. With the BBC in it the original builder placed a radiator down low (below any grille openings). No room for a tall stand up radiator and width of radiator in its present location is limited by the original front suspension and frame.
Ever since we purchased this we have had a overheating issue - pushing fluid through the overflow and out the catch tank. Can't drive more the ten miles. Since then I have reversed the electric fan from a pusher to puller, shroud around the fan as much as possible, run 100% water, tried water wetter, installed high flow water pump, switched to synthetic oil, had the headers jet coated, installed air dams to direct flow to the radiator, installed a good thermostat & cap, installed a surge tank high on the firewall - basically every suggestion that I found on this board or have been told.
Last season at Kalamazoo Street Rods we saw a 37 Willys coming our way with a blown BB. Flagged him down and asked how he was cooling it. He showed us an extra radiator that was tucked up in the wheel well and plumbed with an electric pump.
I am basically duplicating his set up and researching where to draw coolant from. Saw the 3/4 plug in the front of the head and it looked ideal. My return line will be to the heater hose connection on the mechanical pump.
I can hear it now - road debris punching a hole. I asked him about it - said he never had a problem - thought it might have something to do with angles involved.
BBC large port oval head question - 781 JamesRS Engine 4 12-21-2009 06:29 AM
AFR head question Mustangsaly Engine 8 08-02-2006 08:55 PM
BBC tall deck question?? Overdriv Engine 2 07-30-2006 08:47 PM
Head Gasket Question oldschoolrods Engine 5 06-19-2006 11:12 AM
flat head question mercmama Engine 7 03-29-2005 06:59 PM
