With the master on the fire wall you don't need the residual valves, There is one already in the master for the rear brakes. The disc brakes only need it if the master is lower than the wheel cylinders.. The prop. valve you have, if it is a stock one, is a "multi-function valve". It functions as a proportioning valve, turns on the "idiot" light if the system has a problem, and times the front to rear application of pressure.
It will have a stud sticking out that a wire goes to. Usually mid unit.
