Question about Chevelle Brakes - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-14-2004, 03:20 PM
JamesRS's Avatar
Hi all, I have a 72 Chevelle with drum brakes up front. I would like to convert them to disks. What donor cars are compatible so that I can go to the junkyard and pull a set from, and what all do I need besides the rotors, spindles, and maybe brake lines?
Old 09-14-2004, 05:36 PM
poncho62's Avatar
Wiki Edits: 5
You will also need a proportioning valve and the disk/drum master cylinder.
Chevelle, Lemans, Cutlass and Skylark setups are all the same in those years.
Old 09-14-2004, 06:18 PM
wp442's Avatar
Last journal entry: Feb. 03, 2006 - Bed repair 05
Read this page:
http://www.oldsmobility.com/discbrakes.htm
Old 09-14-2004, 11:25 PM
JamesRS's Avatar
Thanks for the posts guys, that page is perfect for what I intend to do.
Old 09-15-2004, 09:28 AM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
Chevelle may be different but on a '68 Nova conversion I had to get the '70's front disc steering arms. The original Nova arms had some intereference issues with the disc brackets and bump stop tang or what ever it's called. I also opted for some new '84 Chevy AstroVan calipers, they bolted right up to the mounting brackets and rebuild parts, pads, etc., should be easier to locate later on.
