question about a chevolet transmission - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-29-2006, 03:15 PM
i have a '88 cavalier and i need to know if a 2.0 motor with a 4cyl. standard transmission will bolt into another '88 Z-24 cavalier body that a 2.8 motor and a 6cyl. automatic transmission was in.
i want to know if it will work and how big a project are we talking?
Old 10-30-2006, 07:20 AM
farna's Avatar
Last wiki edit: AMC V-8s Last photo:
Wiki Edits: 14
The 60* V-6 (2.8/3.1/3.4) uses a different bolt pattern, so won't bolt up. Got this info from Wikipedia -- should be correct but sometimes is off a little. See:
http://en.wikipedia.org/wiki/List_of...using_patterns
http://en.wikipedia.org/wiki/List_of_GM_engines
According to the first article the Family II four cylinders have a different bolt pattern than 60* V-6. According to the second article, the 2.0L is a Family II engine.
I do know that a 1984-2002 Jeep Cherokee/Wrangler 150 (2.5L) four uses the GM small V-6 pattern, so you could bolt one of those in to really throw friends off!! 84-85 has a carb, 86-90 TBI, 91-02 port injection. Might be off a little on the years here, going from memory!
I bet you have a 2.0L in another car you want to use though. If both are Cavaliers of the same body style you can swap tranny and all without much more work than swapping engines -- if you have both cars. Drop the whole engine cradle and suspension from the bottom, use the engine hoist to lift the front of the body up. Well, support the engine with the hoist first, take out all the bolts, drop it, THEN lift the body. I've done this and dropped the engine on a half sheet of 1/2" plywood with a 2" hole about 3" from one side (centered along the side). Put a tow strap in the hole and SLOWLY slide the engine assembly out from under the car (with body on jack stands and hoist out of the way). I used my garden tractor to pull it out, but you can use a truck/car -- just DO NOT JERK or you'll likely rip the plywood and leave the assembly sitting there. Works best on grass with tractor tires on concrete. Damp grass helps -- spray w/water then put plywood down. Okay, enough backyard mechanics!!
1994 Grand Am Transmission fluid question StevenC Transmission - Rearend 0 07-18-2005 10:23 PM
FWD Cadillac Engine RWD Transmission Question Dusty82 Engine 4 03-19-2005 03:39 PM
Transmission swap question shatteredmindofc Transmission - Rearend 1 03-10-2005 02:04 PM
Transmission rebuild question? TonyMac Transmission - Rearend 2 06-08-2004 06:53 PM
Question about astro van transmission??? Robbie Transmission - Rearend 2 05-27-2004 01:50 PM
