question about compression on a bbc - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-15-2006, 10:33 PM
inquiring_mind2's Avatar
a shade tree mechanic
Hello,
I have a 427 bbc that has been bored 60 over with a 3.750 stroke crank, 6.135 eagle rods with 101 cc chambered closed port heads. The pistons are Speed pro domed with a dome of 35.5 cc. the valves are 225 188. I am trying to figure out what kind of compression I have. Any help would be greatly appreciated.
Thanks,
Chris
Old 09-16-2006, 07:24 AM
Will I ever get it done?
Last journal entry: Hood
I come up with 14.7:1. This makes some assumptions. First, the pistons are at zero deck and the gasket has a zero thickness (or the pistons extend above the deck equal to the gasket thickness). Not likely and not good for the engine. It also assumes that the chambers are actually 101 cc, not just nominally 101 cc. Finally, the dome is the net volume. In other words, the volume of the dome less any valve reliefs.
It all makes a big difference. Let's say you have a gasket with a 4.34" diameter bore. It has a compressed thickness of 0.020". The pistons are decked at 0.010". Your heads actually measure out to 105 cc. Finally, you have valve reliefs not included in the 35.5 that amount to 5 cc. These small differences drop the compression to 12:1.
So, to get an accurate number, you need to get out your burette and check the combustion chambers. Check the piston domes. Measure your deck height. Measure your gasket diameter and verify the compressed thickness.
If you have Excel, I can send you a spreadsheet.
Old 09-16-2006, 07:45 AM
the compressed gaket is .041 the the pistons have had .060 taken out out the so the I think it is the exhaust valves do not hit the top of the piston. The block has not been decked. I bought the gasket and pistons from jegs the the part number for the pistons are 844-L2268f60 and the gasket number is 375 1017-1 Sorry I don't havve excel. I wish I had the tools to check all of that out too. LOL The total valve to piston clearence is .110. I don't know if this will help out or not?
Old 09-16-2006, 08:13 AM
The advertised CR is 11.25:1. I would guess this would be close. The only way you are going to be more accurate is to measure everything. You've spent a lot of money and you have a stout engine. The difference between a good engine and a great engine is the details. If you use a burette to check the chambers, you will likely not only find that the volume is different than advertised, but varies from cylinder to cylinder. This is what blueprinting is all about. You make sure all the combustion chambers have the same volume.
Old 09-16-2006, 09:15 AM
72NOVA454
Hi, saw your response. can you send me that excel spreadsheet please.
send to lwallace@pcsoc.com
Boring 396 to 427,and compression question Montegogo Engine 13 02-02-2006 09:09 AM
compression question for 355 Mike_82 Engine 2 12-25-2005 02:23 PM
compression question, 82c10 Engine 1 12-14-2005 05:00 PM
A compression ratio question Centerline Engine 7 11-20-2005 07:52 AM
Compression Question Houman SS '70 Engine 3 03-10-2005 05:28 PM
