The driveshaft u-joints should be OK if you have the pinion set correctly. That much of an offset will show on the finished car. The wheels will be noticably different distances from the body. If the wheels are on centerline,I would not worry about the pinion offset.
A lot of cars came from the factory with the pinion not centred.............won't hurt anything.
Ontario Rodders |
Sanford
Thanks I thought of that and can make that up with a wheel spacer. I guess I was more worried about the U-joints and vibrations. You guys are great thanks for the help.....wont be long now and this thing will be on the road |
| Go Cart? | mustangdude947 | Engine | 23 | 12-20-2005 10:02 AM |
| SBC oil pump shaft question | snod83 | Engine | 7 | 04-15-2004 10:26 PM |
| GM distributor/ Oil pump shaft question | WBrianS | Engine | 8 | 04-15-2004 08:51 AM |
| drive shaft lenths | 37jim | Transmission - Rearend | 5 | 12-11-2003 01:04 AM |
| drive shaft length | tack | Transmission - Rearend | 2 | 07-22-2002 01:06 PM |
