-   -   Question about dupli-color "paint shop" (http://www.hotrodders.com/forum/question-about-dupli-color-paint-shop-119758.html)
indyracer 07-08-2007 09:44 PM
I was thinking about using the paint shop series from dupli-color to do my interior. What I would like to know is if I can use epoxy primer then shoot the dupli-color over it? If so, do I need to use dupli-color's primer over the epoxy first?
Linky to dupli-color paint shop:: Click Here
Countilaw 07-08-2007 11:12 PM
Epoxy primer is only a sealer/bond enhancer. It has not fill properties at all. You should use the epoxy on the bare metal or to seal any paint that you are going to be painting over. Use the Duplicolor primer over the epoxy to fill any imperfections and then apply your top coat.
Frank
indyracer 07-09-2007 07:34 AM
Kinda what I was thinking. I was really just not too sure about using this lacquer based paint over epoxy. Sounds like you can seal about anything with epoxy and then put about anything over it. Great Stuff!!!
