Question about dupli-color "paint shop" - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-08-2007, 09:44 PM
I was thinking about using the paint shop series from dupli-color to do my interior. What I would like to know is if I can use epoxy primer then shoot the dupli-color over it? If so, do I need to use dupli-color's primer over the epoxy first?
Linky to dupli-color paint shop:: Click Here
Old 07-08-2007, 11:12 PM
Countilaw's Avatar
Cox Custom Cars
Epoxy primer is only a sealer/bond enhancer. It has not fill properties at all. You should use the epoxy on the bare metal or to seal any paint that you are going to be painting over. Use the Duplicolor primer over the epoxy to fill any imperfections and then apply your top coat.
Frank
Old 07-09-2007, 07:34 AM
Kinda what I was thinking. I was really just not too sure about using this lacquer based paint over epoxy. Sounds like you can seal about anything with epoxy and then put about anything over it. Great Stuff!!!
383 stroker 73monte Engine 13 05-11-2016 12:17 PM
Question about vehical weight and engine question Thuggishruggish3000 Engine 12 03-24-2011 06:22 AM
question about a previouse question elrod1030 Engine 6 03-10-2010 08:35 AM
Switching to 200R Tranny question Gundarak Transmission - Rearend 4 12-05-2003 09:00 PM
nitrous 69BiRd Engine 2 11-28-2003 11:33 PM
