Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - question about engine breakin???
Old 01-13-2004, 08:19 AM
engineguy engineguy is offline
SAE Member; ASE Master Cert
Robbie,
Are you sure that it is metal? If there was any metal in the engine, it would collect in the bottom of the oil pan. A new engine really should not have any metal floating around in it. Change oil and filter; then install a magnetic drain plug. Any metalic junk floating around in the engine will be trapped by the magnetic plug, but you should not see much on it and certainly no large chunks.
