Question about fiberglass armrest mounting - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-23-2013, 07:09 PM
Hello,
I'm trying my best to follow Dan's advice on building my own door panels for my truck and have got to the point of mounting the armrests. I bought the fiberglass ones that all the hotrod places sell:
I had no trouble matching the insert nuts to holes in the door panels and mounting them but this isn't enough support I wouldn't think. The first person that tries to close the door by pulling on the armrest is just going to pull the panel away from the door. I thought the armrests I saw had an L-bracket that mounted to the inner door and went through the panel?
I guess it would be possible to drill the holes in the panel all the way through the door but i'm not sure how I'd rotate the screw when the panel is on. I'm not sure I'm describing what I'm trying to say but I want to know if there is a trick to mount the armrest to the actual door instead of just the panel.
Thanks,
Jeff
Old 03-24-2013, 07:21 AM
DanTwoLakes's Avatar
Wiki Edits: 22
The best way would be to drill holes straight through the armrest and screw the armrest right to the door through the door panel. That would leave you two or three screw holes. Then you would have to come up with a way to cover the screw holes. You could cut a groove in the armrest where you put the screws and fill it with any number of things to make it look good after the armrest was in place.
Old 03-24-2013, 09:34 AM
sedanbob's Avatar
The guys that did my interior mounted the same kind of arm rest to my door panels using the same screws, but added an "L" bracket that mounted to the door, with one leg extending through the door panel and into a slot in the arm rest. They then drilled a hole for a screw into the leg of the bracket at the bottom of the fingerwell on the arm rest. Hope that made sense.
Old 03-24-2013, 10:06 AM
Use the little plastic push pins like the late model cars use to hold the door panels around the perimeter of the armrest, but under the arm rest. You will drill a hole in your inner door to align with these push pins. These will hold the middle of the door panel when you pull on the arm rest to shut the door. That way it is not major surgery when you remove your interior door panel.
Old 03-24-2013, 10:54 AM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
H'mmm mine have screws right through the arm rests into the door structure but they are on the bottom of the arm rests where one has to get on his hands and knees to see them..
Sam
Old 03-24-2013, 02:51 PM
yep......... I was thinking like 46streetrod........ look at the post of the 32 ford interior I did, used the same armrest and I used push pins like 46streetrod spoke of......trace around your armrest and remove it from your door panel, then prefit it to your door and see where you can drill and add pins all around the armrest....... be sure to put all your pins in the door panel before covering it with your upholstery.......
another trick is when prefitting door panels is to drill a couple of small holes through the panel into the door and put screws through them into the door its self, this way you can take it off and on as many times as you need to by removing the screws and when you put it back on, its always back in the same place each time
added the pic of the door panel I did for you to see............. now, no doubt that screws will be the strongest, this is just another option......
Name:	door panel.jpg
ID:	72566   Click image for larger version
Mounting fiberglass racer57 Body - Exterior 1 12-08-2009 11:21 PM
Mounting fiberglass parts Beenaway2long Body - Exterior 19 10-01-2006 01:06 PM
Mounting fiberglass dash mrmagoo187 Interior 24 11-04-2005 05:43 PM
Fiberglass door / window mounting & hanging powderbill Body - Exterior 10 08-10-2005 07:19 PM
Fiberglass body mounting LoTempio Body - Exterior 1 03-12-2003 08:56 AM
