Question About Flame Treating? - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-25-2010, 05:19 PM
FRANKBULLITT's Avatar
I am repairing a pp plastic bumper and the evercoat poly-flex filler says to flame treat the pp plastic before to promote adhesion.Never did this before.Whats it mean and how do you do it.I always just put on spray adesion promoter . Is it better to flame treat?
Old 10-26-2010, 12:20 PM
crashtech's Avatar
Technician
Last wiki edit: Epoxy primer
Wiki Edits: 17
I've never done it. What we have done here is use adhesion promoter, then epoxy primer. Polyflex can then be applied on top of the epoxy primer.
More typically we will use a dedicated semi-rigid repair material that is designed for use with conventional adhesion promoters.
I think flame treating is stupid.
Old 10-26-2010, 05:09 PM
I contacted evercoat this afternoon an talked to their tech person.They stated flame treating is done by heating up the damaged area before applying the filler.This is done to remove the impurity of the substurate i.e. PP
and promote bonding which cant be done to PP with spray adhesion promoter.So to do this the stated use a light flame from a propane torch or butane lighter over the area.I tried it on a test bumper.1 the old way with adhesion promoter.2 flame treating on the other. Let them both dry for several hours.Then tried to bend and peel back.The test results show they were right.The flame treated piece wouldnt come loose.The chemical treated piece peeled back. Conclusion for repairs on EFDM TPO PP and other promblem plastics best to flame treat.I have implemented this procedure in the shop now, to insure better repairs.I quess you never stop learning with these high tech plastics, which are around us everyday now.
Old 10-27-2010, 02:43 PM
crashtech's Avatar
Technician
Wiki Edits: 17
So your test shows adhesion promoters don't work with polyflex, which was already known. I want to reiterate that I did not nor would I recommend this be done.
I wonder if flame treating also produces satisfactory results with epoxy based fillers made for semi-rigid plastic. There might be a material savings to be realized there.
Old 11-01-2010, 05:43 AM
deadbodyman's Avatar
Wiki Edits: 11
I was wondering about that process Frank ,Thanks for the heads up..
question about a previouse question elrod1030 Engine 6 03-10-2010 07:35 AM
Ignotion Set-ups Native Gearhead Engine 8 11-29-2003 01:20 PM
Hi All I just Joined, Questions Re:454 rebuild Gay-Shark Engine 8 11-29-2003 10:25 AM
Unique Flames Question way_2fast_4u Body - Exterior 5 06-04-2003 03:13 AM
another flame question Conner Body - Exterior 5 03-01-2002 03:26 PM
