question about a ford 9 inch - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-15-2006, 08:39 PM
38 old coupe's Avatar
Last journal entry: Electric windows
hello i was told you could change center section pumpkin out with out pulling Axel's is this true? i all ways thought you had to pull the Axel's out first thanks kelly
Old 04-15-2006, 09:04 PM
You have to pull the axles.......
Old 04-15-2006, 09:25 PM
k thank you i thought so he was saying the spider gears was in the axel tubes and when you slid the 3rd member in it slipped in to the spiders thanks again kelly
Old 04-15-2006, 09:40 PM
M&M CUSTOM's Avatar
Wiki Edits: 9
9-inch spider gears are in the carrier and come out with the rest of the center section.
which 9 inch Ford to use dbell Transmission - Rearend 3 02-28-2006 08:17 PM
9 inch ford to 56 chevrolet ray bob Transmission - Rearend 3 01-27-2006 04:19 PM
Ford 9 inch to Chevy 4.75 pattern questions 3100 Special Transmission - Rearend 14 01-21-2006 08:29 AM
9 inch ford setup question Eric327 Transmission - Rearend 8 01-18-2006 09:31 PM
1973 Ford 9 inch disc brake conversion question Steve-0321 Suspension - Brakes - Steering 2 12-17-2005 09:47 PM
