Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Question about frame off reso.
Old 10-17-2009, 07:08 AM
Irelands child's Avatar
Irelands child Irelands child is offline
If it's a hard top or, especially, a convertible I would probably install some cross bracing - 1" might be a bit heavy and a pain to work around with 3/4" being a enough smaller, a fair amount cheaper and much easier to work with. If it's a coupe, a couple of braces across the bottom would keep the sides parallel if you take the entire floor pan out all at the same time. It's too late if you don't spend some time and some bucks now, rather then lots of time realigning the body later IF the car panels move too much.
Dave W
