Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Question about frame off reso.
Old 10-17-2009, 02:57 PM
joe_padavano joe_padavano is offline
I would suggest tack welding in cross bracing, mainly to keep the shell square when you cut the floor out. If the floor is really that bad, there is now a full floor pan (including the section under the rear seat) available as a repro for the 64-67 cars. It's not cheap, but it makes the job much easier since you simply weld it on at the factory spot welds.
