Originally Posted by joe_padavano
I would suggest tack welding in cross bracing, mainly to keep the shell square when you cut the floor out. If the floor is really that bad, there is now a full floor pan (including the section under the rear seat) available as a repro for the 64-67 cars. It's not cheap, but it makes the job much easier since you simply weld it on at the factory spot welds.
yeah, I came across them for the tune of 8xx but, just like you said, much less work to put in one piece vice having 6 to fit, trim, refit, square up then weld in... Thanks for the suggestions guys, Ill fire up the welder here shortly (by shortly i mean atleast a month, life on a destroyer sucks) and get it ready to go into storage to work on the frame
