If it's a hard top or, especially, a convertible I would probably install some cross bracing - 1" might be a bit heavy and a pain to work around with 3/4" being a enough smaller, a fair amount cheaper and much easier to work with. If it's a coupe, a couple of braces across the bottom would keep the sides parallel if you take the entire floor pan out all at the same time. It's too late if you don't spend some time and some bucks now, rather then lots of time realigning the body later IF the car panels move too much.
Dave W |
I would suggest tack welding in cross bracing, mainly to keep the shell square when you cut the floor out. If the floor is really that bad, there is now a full floor pan (including the section under the rear seat) available as a repro for the 64-67 cars. It's not cheap, but it makes the job much easier since you simply weld it on at the factory spot welds.
How tough can it be to find a solid '67 Cutlass to start with? Geez Louise!!! Part out that turd and start over.
Guy |
| A RatRod type frame question | SixEightFury | General Rodding Tech | 2 | 08-12-2009 06:17 AM |
| Another S10 Frame Swap Question | joedcu2 | Suspension - Brakes - Steering | 3 | 07-28-2009 02:18 AM |
| 41 Plymouth Frame question... | Tyroma | Suspension - Brakes - Steering | 12 | 12-21-2008 08:14 PM |
| Thru Frame Fitting Question | dlc1979 | Suspension - Brakes - Steering | 2 | 07-14-2008 06:55 AM |
| Frame question | screamin340 | Suspension - Brakes - Steering | 2 | 08-21-2005 09:00 PM |
