Question about hooking a msd blaster coil to a msd dizzy - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-28-2008, 11:30 PM
tiresmoke55's Avatar
PO-BOYS-TOYS!!
Last journal entry: My new 55 chevy pretty sharp
Hey guys i have a quick and i hope a easy question,,, I have a pn 8360 msd dizzy and a blaster 2 coil and im having trouble getting fire out of the coil.
BTW Im NOT running a msd 6al box..
The dizzy has 3 wires off it. red, orange, and a black. what wires from the dizzy hooks to the coil???
and also what all other wires should be running to just the coil?? the blaster 2 is just the round style coil... everthing on the net show how to hook up a msd box,, and not a msd dizzy to just the coil... any help would be great thanks
Old 04-28-2008, 11:34 PM
Blazin72's Avatar
You got a leaky spark tube...
Last wiki edit: Rearend removal
Last journal entry: General Lee
Wiki Edits: 19
It's quite simple:
http://static.summitracing.com/globa...structions.pdf
Page 6 has wiring instructions.
Old 04-28-2008, 11:47 PM
PO-BOYS-TOYS!!
Thanks very much for that info,,, Butt now i have another problem i thought that was the way it went and mine is ran like that Red to + / orange to - and black is ground,, and i have power to the coil, i stuck 3 new coils on it, and im still not getting any spark out of it... only time it will spark a little with my tester on it is when you first turn the key on and when you turn it off,, butt no spark when cranking??? also really quick with the key on both the - and + side of the coil is hot but hit the key and my test light goes out?
Old 04-29-2008, 01:15 PM
Drewnashty's Avatar
sitis nam accelero
Test the 12v feed to make sure it is getting a full 12 volts and check the ground wiring. Was this motor running before the MSD coil and dizzy were swapped on?
Old 04-29-2008, 04:41 PM
PO-BOYS-TOYS!!
Yes it was running fine,, all did was switch motors in the car,,, it does have power to the coil
Mallory coil vs. MSD Blaster 2 McDeuce Electrical 10 02-29-2004 08:57 PM
6 volt / 12 volt coil question BillyJoe Electrical 3 01-21-2004 05:38 PM
Coil over Question Will's41 Suspension - Brakes - Steering 2 07-31-2003 09:07 AM
Coil question Mickey Spillane Electrical 3 06-12-2003 12:44 PM
coil question Brick Engine 1 05-12-2003 05:35 AM
