-   -   Question about new paint booth floor? (http://www.hotrodders.com/forum/question-about-new-paint-booth-floor-126819.html)
FRANKBULLITT 10-22-2007 07:16 PM
I have just installed a new booth on a cement floor inside the shop. The booth is semi down draft.Anyway to make a long story short what kind of a coating should I put on the booth floor.Its now just bare concrete with no coating .
302 Z28 10-23-2007 05:59 AM
You can just leave it natural concrete if you wish, but painting it will make it easier to see trash and easier to wash down. A lighter color of off white or gray would work fine. The lighter color will help in the lighting of the booth.
Vince
FRANKBULLITT 10-23-2007 07:46 AM
thanks for the response , but I was wondering what type of paint to use which would hold up and work best ?
duallybuster 10-23-2007 07:55 AM
Put a concrete sealer down on the floor, We had a regular concrete floor on our booth and over time the floor got caked with overspray. We recently up graded to the downdraft booth with it's own basement pit. Don't have to worry about overspary cake anymore. One thing that I noticed with the concrete floor is that when we shoot single stage it was worst than BC/CC as far as the overspay cake. G/L
Corey
302 Z28 10-23-2007 10:55 AM
The home supply houses carry an epoxy garage floor paint that should be great to use.
Vince
speede5 10-23-2007 12:03 PM
Whatever you do use a good two part epoxy, not the cheap stuff you can get at home depot but a good industrial one. Also etch the surface really good prior to coating. surface prep is 3/4 of the battle. Amerlock makes a great two part that will be hard as rock. You really have to watch when you apply it you don't want to be trapped in the room and it needs a few days to air out but you won't wreck it. It doesn't cost much more than the cheap kits at the major lumber stores either.
GOOD: http://www.cgedwards.com/ameron/400prod.htm :D
NOT SO GOOD: http://www.behr.com/behrx/act/view/p...tings&catId=16 :pain:
