Question about a NOTrod car... - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 06-06-2011, 05:40 PM
T-bucket23's Avatar
Wiki Edits: 26
Check pin 16 of the dlc connector for 12 volts. It is powered from the B?Alarm fuse under the hood
Chet
  #17 (permalink)
Old 06-07-2011, 09:02 PM
Augusto's Avatar
From the middle of the world
Last wiki edit: How to rebuild an engine Last photo:
I had a customer's car once with a code that didn't go away, with the scanner or disconecting the battery, I first disconected the battery and then turned on all the switches I found in the car, (lights, radio, turn signal, hazard, horn, etc etc,) thinking that this would drain off some sort of reserve energy the ECM somehow may have stored feeding the RAM and ROM, like in it's capacitors or something, well it did worked, the problem was fixed, it was a Toyota.
Question about vehical weight and engine question Thuggishruggish3000 Engine 12 03-24-2011 05:22 AM
sbc timing question and carb question.....i am ready to absorb your knowledge c_cham Engine 16 02-12-2011 11:26 AM
steering question and brake booster question Hwyhogg Suspension - Brakes - Steering 0 11-21-2010 05:02 PM
Timing question and cylinder head question.. Blackhauk90 Engine 2 05-22-2007 01:10 PM
not a rod question but an engine swap question for a daily driver.. DeathByGreaser Hotrodders' Lounge 2 01-22-2004 10:59 PM
