Question about a NOTrod car... - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-03-2011, 12:50 PM
el pollo's Avatar
It's shady under this tree...
It's my daily. I have a 1998 Elantra that I use as daily transportation as it knocks down 30MPG on my 43 mile each way commute.
The problem I have is a few nights ago, it threw a code. No big deal. Missfire on #3. Cleared the code, and bought some plugs. Today I go to the inspection station to get it inspected, and realize I have another, bigger problem. NC state inspections do a two step process from what I saw. Scan with engine off, then engine on. The scan when off goes through fine, but it seems that every time the engine is cut back on, the computer clears it's self and won't communicate with the state computer.
Anyone seen this before? My own scanner communicates fine. The guy at the inspection station used his own scanner and everything checked out fine. The state computer, which makes all of the relevant sensors report back, won't communicate.
Old 06-03-2011, 12:59 PM
dinger's Avatar
Would it help to disconnect the battery for an hour or so, then reconnect?
"When I was younger, I could remember anything, whether it had happened or not." - Mark Twain
Old 06-03-2011, 02:41 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
It sounds like the problem is on THEIR end, not yours. Can you use a different inspection station?
Old 06-03-2011, 04:23 PM
techinspector1's Avatar
Wiki Edits: 326
Good luck. NC is my home state and never in my life have I ever encountered so many ignorant, inbred buffoons who haven't a clue. Well, maybe Alabama.
Old 06-03-2011, 05:17 PM
el pollo's Avatar
That could work, but I'm thinking it would put me back to square one. See, I cleared the code the night before. Drove 86 miles on it, and still ended up with two copies of an incomplete inspection that had too many "not completed" checks.
The 02 sensor, Evap system, catalyst, and 02 sensor heater all came up as "not completed" data. So I drove the car around town, filled up the tank, and went back to the station. The inspector checked it in the parking lot and said it'll pass (I hadn't cut the engine off), and pulled it into the bay. He hooked it up to the computer, and it went through the first phase fine. Cut the engine off, and did the second check. It then asked to start it up again. The third check came up as incomplete. So he logged off the computer and rebooted it. Still the same thing.
I go to this station because the guy is honest and up front. He's never lied to me and helped me out the best he can when something is wrong. He also knows if there was ever anything wrong, I'd fix it because I hate having broken vehicles.
Tech, you're right. Most (not all), are some of the dumbest people on the planet. I think it's because inspector mechanics are always the greenest guys in the building. Seems that if you want to turn wrenches in North Carolina, you have to go through state inspection training first. the smart ones move on...
Old 06-03-2011, 06:46 PM
LATECH's Avatar
Chances are you have a malfunction that generates a trouble code .
That would result in a monitor(or 2) not resetting wich is what is failing your car on the OBD test. Some pennsylvania countys have an obd test and some have just a gas cap test.The counties that have the OBD test hook to the car like North Cackillacky does. In Pa if your car is obd II all the monitors have to clear as running and The MIL cannot be on.
However an emmision waiver can be granted if a certain dollar threshold has been met as an attempt to repair the emission issue and results are not obtained, allowing the owner to operate the vehicle on the premise that it will cause a hardship for the owner, and money has been spent to attempt to repair the problem , unsuccesfully.
Not sure if N C has a waiver type sticker it is worth asking the inspector.
Lack of vehicle communication while running may be due to the self check system ( monitors) is keeping the PCM too busy to communicate with the state computer, due to the operational strategy and memory capacity it needs to perform all the system tests
I would suggest trying to repair the issue .Monitors wont reset if the system in question is developing a malfunction.
Drive it for a day or two, see if it sets a code, look for one trip codes(pending) and if there is nothing, look at the live data for discrepencies.
Keep us posted
Old 06-03-2011, 06:56 PM
el pollo's Avatar
I'll definitely keep ya'll posted.
Old 06-04-2011, 09:27 AM
tnsmith10's Avatar
when will it rain???
man do you have that right! beautiful landscape and the people there are nice. but, theyre not too bright out there...
Old 06-04-2011, 06:14 PM
el pollo's Avatar
I shake my head when I see something (daily) stupid. I personally am not from North Carolina, but my extended family is. The biggest thing that drives me nuts is seeing guys pull out Richmond 6 speed trannies and stuff in a powerglide and then sell the Richmond for practically peanuts. Same with fuel injection systems because their uncle says nothing beats a Holley. Just two days ago my neighbor was going to attempt to pull his 30+ foot pontoon boat with his wife's Sequoia because he couldn't fit everyone in his Avalanche. Even the Avalanche was overloaded. I gave him the "You're stupid" look and he decided against it.
Yep, I am looked upon as a strange character in these parts. Backwoods redneck, no doubt. But I seem to have the upper hand in the common sense department.
Anyhow, an update. I have changed the plugs, and bought a fuel filter and a can of MAF cleaner. I'm grasping at straws being as I have zero trouble codes. The filter, as far as I now, hasn't been changed in a long while...
Old 06-05-2011, 06:51 PM
el pollo's Avatar
Okay, so I got my hands all cut up today. Changed the fuel filter, which is located just under the brake booster, just behind the transmission mount and has every freaking brake line next to it in a web of major cluster-what-the-F... I also cleaned up the MAF sensor.
Anyway, the car runs much better now. But just in case, I scanned the OBDII just to make sure everything was okay. I found these two codes: PO743 and PO747. Torque convertor clutch circuit electrical and pressure control solenoid stuck on. Now, the transmission seems to shift fine (except for a few times, where it would suddenly downshift, which I was able to trace to the TPS). Now, can trouble codes with the transmission cause the inspection station computer act weird and not be able to read the car;s computer? The check engine light was not on when I scanned it...
Old 06-05-2011, 08:30 PM
LATECH's Avatar
I would have to guess at that one, but It would be yes.It is malfunctioning and it will keep some of the emission monitors from resetting to complete.
the system monitors are sequential one has to complete before the next( i dont recall the priority or the order) but one can keep the others from complete there routine.A trans problem like that may keep any one of the monitors from running and completing, wich the state computer is seeing and failing your car for.
Post the monitors that are not complete,i will have a look tommorow as to a more specific cause.
If you have some sort of TPS issue, that may be the root cause of the trans malfunction as shift points use TPS value(and several others) to create shift points.
Old 06-06-2011, 05:38 AM
el pollo's Avatar
I replaced the TPS about two months ago. It's also listed as a transmission kickdown sensor. That was actually the code I was getting. So the TPS got replaced, and it hasn't been screwy since. But still, every once in a while I get weird transmission codes that come up even though performance-wise, nothing is wrong at all. I'll probably be irritated when I finish replacing stuff only to find out the computer was to blame all along...
Old 06-06-2011, 05:32 PM
LATECH's Avatar
I would be checking wire connectors closely, they could very well be problematic. I had a toyota once that had a broken wire in the wire harness where it jumps from the engine to the body, it was a ground splice right in the middle and the wire had one broken at the crimp where 3 were spliced together.Took a little checking to finlly find it, boy was the customer happy.
Look into the connectors for deformed pins and clasps,also look into the back of the connector for the green fuzzy stuff( oxidized copper) a good sign of a bad connection.I would check at the trans connector first as you said sometimes you have a symptom with that.
Old 06-06-2011, 05:48 PM
T-bucket23's Avatar
Wiki Edits: 26
Check the fuse for the cigarette lighter. This fuse also powers the DLC connector in a lot of cars. Not sure on Hyundai but it is worth a look.
Chet
Old 06-06-2011, 06:22 PM
el pollo's Avatar
I'll check that, although the connector works, and the lighter has never worked since I've had the car.
I'll also check the wiring harness tomorrow, I'll just look at the ones to the trans and backtrack.
Question about vehical weight and engine question Thuggishruggish3000 Engine 12 03-24-2011 06:22 AM
sbc timing question and carb question.....i am ready to absorb your knowledge c_cham Engine 16 02-12-2011 12:26 PM
steering question and brake booster question Hwyhogg Suspension - Brakes - Steering 0 11-21-2010 06:02 PM
Timing question and cylinder head question.. Blackhauk90 Engine 2 05-22-2007 02:10 PM
not a rod question but an engine swap question for a daily driver.. DeathByGreaser Hotrodders' Lounge 2 01-22-2004 11:59 PM
