Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Question about Oil presure on a 350 sb???
Old 09-27-2012, 09:58 AM
BlazerMan80 BlazerMan80 is offline
With the engine hot the stock specs for a 350 are 15-20psi at idle-in gear. With the addition of about 100 rpms the pressure should be 30psi. At 2000 rpms the pressure will be 45-60. This is with a regular oil pump. With a high pressure you will be 10 to 15 higher on all specs, a little also depends on your choice of oil, but not that much. Good luck.
