Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Question about Oil presure on a 350 sb???
Old 03-02-2004, 07:53 AM
troy-curt's Avatar
troy-curt troy-curt is offline
Shop Owner And Troll Hunter
A high volume pump should not increase the pressure, How ever it will put more oil on the top part of the engine, thus leaving less in the oil pan for the pump to work with. When a customer wants a high volume pump, I use pipe cleaners in the push rods to cut the flow to the rocker arms. I have seen them fill the valve covers so that the valve stems was standing in oil. causing excessive oil consumption.
Troy
If you don't make mistakes. your not doing anything.
69 ss rs full custom camaro 98 ISCA grandchampion
69 ss rs bb camaro wifes driver
66 Elcamino 350/all dz parts,ac,windows,loaded,my driver
69 ss chevelle bb conv.fresh frame off
26 T sedan street rod
