Question about old Chromaclear activator - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-12-2010, 07:55 AM
cyclopsblown34's Avatar
Colorsanding painter
I have about a dozen never opened cans of Chromaclear 7500 various temp activators from 94 or so. They're all still fluid and I was wondering if it could be any good any more and is there any use for it with any of todays products.
Thanks in advance,
Chip.
Old 10-12-2010, 08:49 AM
Unopened, they should be fine, unless they were exposed to a lot of cold temperatures, where the inside of the can created condensation, even then, they should be fine but will go down hill fast once exposed to air.
(iso's cure with moisture and air)
Best thing to do is just pour a little clear out on a lid or can top, dab some activator and mix, don't worry about the exact ratio, mix with a stick and let set over night, if still reactive, it will be hard, if not, you will know in morning.
Old 10-12-2010, 08:52 AM
Thanks Barry, I'll give that a try with one of the unopened ones here in the near future.
Old 10-13-2010, 09:16 AM
deadbodyman's Avatar
Wiki Edits: 11
As far as what clears it'll mix with ,I'd say any urathane clear or SS paint with the same 4:1 mix ratio.
Old 10-14-2010, 12:00 PM
Thanks Michel. I'm gonna try it with some Nausea clear on my next, oops, I din't have time to order SPI project.
Old 10-14-2010, 12:12 PM
WOW!
Risky at best, 4:1 activators may be 30% solids or the highest one we make is 90% and everywhere in-between. Paint will dry but if ratio is off never cure out fully or it could be over activated.
Might be good for door jamb or cutting in but I would never put this on the outside of a car without the proper activator.
Old 10-14-2010, 12:19 PM
Is there a good way to dispose of it?
Old 10-14-2010, 12:28 PM
Not sue if that clear was replaced with another clear or not, if not buy the activator, if it has been replaced, check with jobber to see what the replacement was and if that activator will work.
Even if replaced, companies don't change their strips and solid content would most likely be real close.
Other option is start mixing any activators with it so it sets up.
Old 10-14-2010, 12:32 PM
shine's Avatar
SPI Thug
Last journal entry: some progress
recon it will work in 7900 ????
Old 10-14-2010, 07:27 PM
Dam where were you a few months ago? I had a gallon of old 7500 but no activators. I used Nason activator in it and crossed my fingers. Supposedly the Nason clear is just the old 7500 anyway. So far so good.
Old 10-15-2010, 04:32 AM
Wiki Edits: 11
I used to love that 7500..
Old 10-15-2010, 09:45 AM
So did I. That's the clear I learned with.
Fuel System question Ratoflic Engine 6 01-23-2010 12:10 PM
383 stroker 73monte Engine 10 12-05-2009 08:02 PM
Valspar DTM 2K Primer-Sealer Question danny_g Body - Exterior 4 09-02-2009 04:42 PM
spi 2k primer activator oldcarguy36 Body - Exterior 19 11-17-2006 11:45 AM
nitrous 69BiRd Engine 2 11-28-2003 10:33 PM
