Question about Olds 455......... - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-02-2008, 04:24 PM
I am interested in buying a 77 Olds Omega with a 455/turbo 350 in it. The owner says the block casting is 396021 F and the heads are "C" heads. Is this engine well suited for rodding? What kind of power should the engine make (considering stock parts)?
Old 01-02-2008, 04:31 PM
DoubleVision's Avatar
The Olds 455 is a undersquare engine, meaning the stroke is more in inches than the bore size. with a 4.125 inch bore and a 4.250 inch stroke, this engine says one thing loud and clear, Torque. these engines are torque beasts, and in street form will shred tires to rims in very quick order. You can look at the father of olds Rodding, Mondello, you can learn much just by visiting his web site.
http://www.mondello.com/
Old 01-02-2008, 05:38 PM
That's a nice lightweight combo. All 455s have that same block casting number. The C heads were made in 67-69 and are good flowing heads. It sounds like you might have a 68-69 motor, which is a good thing. Those heads could have come with either 2.000" or 2.070" intake valves. The only way to know is to pull the heads and measure. A stock 68-69 455 was rated at around 360-390 HP and 500 ft-lb of torque (though those are the earlier gross ratings, not the 1971-later net ratings).
Old 01-02-2008, 06:15 PM
Mustangsaly's Avatar
realoldspower.com can help ya out. theres some SBO & BBO Freaks over there that know there stuff. that 455 has potential and as said is a torque monster. mondello don't have a great name anymore.
these sections over at realoldspower.com will do ya some good.
General Engine Tech
Engine Builds\Combos
For Sale
Look Up Mr. Olds at realoldspower.com
Old 01-02-2008, 09:33 PM
Thanks for the replies, guys. I hope to get this car so I can drag race against my dad, not just bring him to the track. With 500 lb/ft torque in the Omega, he'd prolly beat me though. How well should the turbo 350 hold up to the gorrilla-like torque numbers?
Old 01-03-2008, 11:18 AM
Depends on how well the rear tires hook up. If you plan to run slicks, a stock TH350 likely won't last long. A built TH350, however, is a good solution because it has less internal HP loss than a TH400.
455 Olds repower for 5.7 Diesel - Headers? 66GMC Engine 2 12-25-2005 08:15 PM
67' merc Olds 455 53fordguy Engine 8 12-10-2004 09:37 PM
455 olds Vs. 500 caddy HELP! Kenny13z3 Engine 9 10-05-2004 05:15 PM
455 Olds 53fordguy Engine 7 04-27-2004 04:38 PM
olds 455 build up oldscutlass Engine 1 06-24-2003 08:57 PM
