Question about paint - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-14-2011, 07:01 PM
Hi i have what might be a noob question. I have been painting about a year and a half now and i am currently doing a basic scuff and paint job. I have sanded everything down with 400 grit then scuffed with red scotch brite. Thats all. My question is some spots i didnt hit with 400 grit as well as others but i scuffed everything with the scotch brite very well. My question is will this create a problem for the areas not sanded as well as others. here is a picture for reference. Obviously the shinny areas are what i am wondering about. thanks for the input. sorry if it sounds confusing
Old 07-14-2011, 08:07 PM
302 Z28's Avatar
I would go over the shiny areas again before painting and do a really thorough pre cleaning with hot soapy water.
Vince
Old 07-15-2011, 05:50 AM
BarryK's Avatar
Like Vince said, those shinny spots are a problem waiting to happen, needs to look like the top half does.
Old 07-15-2011, 07:29 AM
what can happen if i were not to fix it
Old 07-15-2011, 07:32 AM
BarryK's Avatar
Just weaker adhesion, more likely to stone chip and chips may be bigger then normal, some flaking if hit in just right area.
Old 07-15-2011, 09:06 AM
deadbodyman's Avatar
Wiki Edits: 11
I've tried to do some cheap scuff and shoot jobs for a couple customers that didnt have the money to do it decent. but every time I ended up sanding it down the way I always do because its not that much extra work and I feel much better about it. The only way to do a scuff and shoot for me is to send those cars to the econo paint shop up the street. Personelly, I'd much rather NOT work than do bottom of the barrel work. It'll ruin a good rep or prevent you from getting a good rep.
Avoid scuff & shoots at all costs ,give them a proper sanding and eat the extra labor,Unless your working at the econo paint shop then you gotta do how they say at least its not YOUR rep. that suffers
Old 07-16-2011, 09:48 PM
I have been using blend prep with a scotch brite pad for light colors and it works pretty good. Just have to give it a good rinse afterwords.
Old 07-17-2011, 04:59 AM
BarryK's Avatar
PERFECT, you know thinking about this , this is something no one seems to recommend and we should be promoting this for perhaps the newer painters to eliminate some of the fish-eye problems.
I keep a stock pile of Scuff and stuff (like the blend prep) and it makes for a good cleaner and sanding all in one in a case like above, where they are just sanding existing paint that is in good shape.
Works real good for interior parts and sanding new raw plastic bumpers also.
Old 07-17-2011, 10:25 AM
The original poster never said if they were sealing it or not but you should never use a red scuff pad on any silver or light metallic color as it will show all the scratches.
Old 07-17-2011, 10:56 AM
Wiki Edits: 11
WHAAAAAT? where did you hear that??? if you can see scuff scratches maybe you need a second or third coat of paint and the color has nothing to do with it.
RED scuff pads are for scuffing before paint
Gray are for scuffing when something just gets clear ,like a blend
Old 07-17-2011, 12:31 PM
I had it happen when I replaced a fender and blended into a door. I used a red scotch brite on the door and you could see the scuff marks in the base coat. Thats why I like to use blend prep or sand it with a 1000 grit.
Old 07-17-2011, 02:03 PM
Yeah i was always told to use red scuff pads before sealer and paint
H of K paint question cxpcman Body - Exterior 14 07-23-2007 01:21 PM
what if paint question pepi Body - Exterior 6 06-28-2007 06:11 AM
Paint question yleefox Body - Exterior 8 05-28-2007 07:22 AM
Paint Question. What info does the paint shop need... Pencilneck314 Body - Exterior 6 02-06-2004 04:30 PM
Question: Paint Derek1987 Body - Exterior 3 11-20-2003 04:50 AM
