Question about paint cracking on fiberglass - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 07-21-2009, 06:54 PM
shine's Avatar
SPI Thug
Last journal entry: some progress
well i guess it will remain a mystery . there is no gel coat on corvettes. never was. the early cars were done with white resin then later it went to gray . you can look at a virgin body and see fibers on the surface. the easy sanding gel coat is actually the factory primer that does not come off with stripper most of the time. i took it off the 62 with type6 acrylic , the 57 was do degraded i had to stop blasting and change to a softer media. the dark gray is what is mistaken for gel coat. as you can see in the pics of the new bodies there is no dark gray gel coat . just resin and fiber. somewhere i have a book on the vette bodies . gm didn't build them . i'll look for it.
but the bottom line is epoxy is the only product proven to work on the polyester resins once cured. it is recommended for repair and i use epoxy for surfacing. reason being it's adhesion qualities both for sticking to the polyester and for hold out in paint. jmho
ID:	39571   Click image for larger version
Name:	lf fender.jpg
ID:	39572   Click image for larger version
  #17 (permalink)
Old 07-22-2009, 12:26 AM
Thanks for the help guys. Sounds like the epoxy oughta take care of it. I haven't kept up with auto paint and the current materials for a long time, so I didn't know in advance of posting here that epoxy primers were being used in auto paint work now.
I have used high build epoxy primer of the industrial variety on equipment that's been blasted, and on stuff like that, you can topcoat with straight enamel or acrylic enamel, and it'll hold up near about forever. The same prep, but use conventional primer, and if it goes 5 years without rust beginning to bubble the paint here and there, its pure luck. So, from the standpoint of durability, etc I'm already a believer in epoxy primers, and its good to find out they're available in automotive formulations now.
Shine, re the Vette bodies, they've been made from day one by MFG (Molded Fiberglass Corp). They still make them today even though the materials and processes have changed over the years.
MFG was the first mass producer of fiberglass boats too, although I'm not sure they still make them. They got into making boats when GM stopped Corvette production sometime in 1954. If you recall, that carried into 55 as well, and accounted for the low 55 production volume, so the shutdown lasted a good while. MFG had built a new plant based on having the Corvette contract, and when GM stopped production they were suddenly in a what're we gonna do now situation.
They were set up in that plant for making big parts, so they figured a boat hull was a good way to keep it busy. They made some hulls and approached a few of the then-current wood boat builders, but none of them were interested. Most of them said fiberglass boats were something that'd never catch on with the public. Sounds about like some of my own dumb predictions of future trends
Anyway, they decided if no one else wanted to buy the hulls, they'd just build the complete boats themselves, so that's what they did, and quite successfully too for a number of years.
MFG today is a big company, involved in about every aspect of composite production. But they're still owned by the family of the man who started it. He's dead now, but his son has been the head of it for the last 20 or 25 years. They probably owe a lot of their success to a lack of stockholders, Wall St parasites, and Harvard MBA's.
Again, thanks for the paint tutorial.
Cliff
  #18 (permalink)
Old 07-22-2009, 05:41 AM
shine's Avatar
SPI Thug
from bread trays to vette bodies . funny part is mr morrison had no idea how he was going to do it but he got the contract and went for it. i don't know how many corvettes i have done but there have been a few. in my younger days i free lanced at dealerships doing vette work. most of the bodymen and painters wanted nothing to do with them. when i would take a skill saw to one they took off. i'm blessed that glass does not bother me .
my next vette project will be a 54 restomod. maybe . i have a project of my own to do so i may just shut down and do it.
  #19 (permalink)
Old 07-22-2009, 04:13 PM
cr55's Avatar
If I'm not mistaken, you have a bunch of projects to do!!!!!(shop truck, inderweeds, just to mention a few)............CR
  #20 (permalink)
Old 07-22-2009, 05:22 PM
302 Z28's Avatar
TubeTek, don't substitute any other brand for SPI, it really is "hands down" the best epoxy primer you can buy. It is far superior to both PPG and DuPont in durability and price. I tried a little experiment with some PPG that had been sprayed on my steel 34 hood for several months. I soaked a rag in lacquer thinner and made a swipe across the hood.......the PPG epoxy wiped off . Needless to say I removed all of it and then sprayed on SPI. After several days cure I tried the same thing....it didn't wipe off. I can't stress enough how good the stuff is.
Vnce
  #21 (permalink)
Old 11-03-2012, 02:45 AM
old guy's Avatar
Old thread but great info..
two tone paint question makaveli200369 Body - Exterior 1 05-11-2009 02:36 PM
fng paint question. oldguy829 Body - Exterior 1 09-17-2008 06:16 PM
Paint repair of roughly 3"x3" on a fiberglass bumper killerformula Body - Exterior 2 01-11-2008 04:12 PM
question about type of paint maaco uses project66 Body - Exterior 7 10-24-2004 07:33 PM
Primer and Paint on Fiberglass? Biggarmike Body - Exterior 10 01-11-2003 05:45 AM
