Part of your problem is lacquer, it is not durable and will craze (crack) over time if too much clear has been applied. The answer to your problem is a quality BC/CC. The first thing you need to do after removing all the lacquer products is to seal the surface with a quality epoxy primer. You can spend tons on a high profile epoxy primer like PPG or DuPont and not get the quality of SPI for lots less money. Once you have several coats of SPI epoxy on the body you can then apply some blocking primer. There is a member on this board who has extensive knowledge of body work on Vette's, his usersname is Shine....PM him or wait for him to reply to this thread.
Vince |
Thanks Vince. I'd agree with your comments in general regarding lacquer, but I'm pretty sure this is some underlying problem with the glass itself since GM's original lacquer job failed in the same time frame and same confined area as both of mine have. There's no clear on the car, and not a sign of stress cracking anywhere else on the paint.
Assuming the problem is under the paint, and not the paint itself, I'd be hesitant to try anything paint-wise without first doing something to the door, whatever that something may be. Its sorta like if you were to paint some structural fabrication and a weld cracked later on. Regardless of what paint or primer is on top, the crack is gonna come thru. I'm pretty sure this is happening from the panel surface outward, particularly since it came right thru the feather-fill as well as the primer and paint. I do plan to take everything to bare glass, and start from there with epoxy this time. Last time I painted the car, the BC/CC paints were just getting popular and the carmakers were having paint failures left and right, so I decided not to experiment in that direction. No doubt today BC/CC is the only way to go on any vehicle that's worth the effort of repainting. Cliff |
redo the car with epoxy . forget polyester as it will allow the print to telegraph through . what happened is the lacquer checked and the glass "took" the print. fiberglass is after all polyester. if the area has any damage then sand it down good an put one layer of veil cloth over it.
i use only epoxy on corvettes . no polyester and absolutely no junk urethane primer. good luck with it. |
I'm not sure that I would concur with taking it down to bare glass again. To quote one of my knowledgable friends "nothin sticks to paint like paint". There are times when removing the paint is required, it is useful when you have metal and need to weld or de-rustify, or with fiberglass when you need to make a repair, or when layers of paint are too thick to work with. Unless the paint is lifting, you can rely on the paint that was applied in the 80s to be good enough to work with. You will need to remove the paint on the door that has the problem.
Frequently the mako bodies had paint problems from the factory. Your problem is not that uncommon, because the gel coat (epoxy) layer was not properly applied, or was removed during fit and finish before painting, the paint will not adhere properly to the polyester (fiberglass). You will need to work the door down, apply a gel coat, then finish and prep to paint. When you work the door, be sure to allow for matching the door to the fenders - that may be why you're gel coat is lacking, the factory took it down to match the fenders before paint and removed the gel coat. |
there is no gel coat on a vette body .
With all due respect to Shine -
Corvette bodies prior to 1983 were constructed of Glass Reinforced Plastic (GRP), made of fiberglass and thermosetting plastic (polyester resin). When epoxy is used it is GRE vs GRP. The body panels are made from a moulding process. Starting with a buck or plug to form the desired shape, the panels are construced by: 1) Applying a release agent (wax or PVA) to the plug; 2) Applying a gel coat; 3) Formed using a hand lay-up process (applying layers of fiberglass mat and resin). Boats are made with a finish coat of pigmented resin that is also referred to as a gel coat. This is not what I referred to when I addressed the crack and peel issue above. When you remove the "paint only" from a corvette body, you will find that there is a smooth layer of hardened polyester resin "gel" coat on top of the panel. If you take a sander to it you will quickly work through the "gel" coat and find exposed glass fibers. Continue sanding to find more exposed glass fibers. Attemptimg to prime and paint over these fibers produces poor results, often the result over time is the paint cracking. Your recommendation to use epoxy (or epoxy paint) produces the desired result because the epoxy is essentially a thermosetting plastic that bonds with the exposed fibers and once it is cured makes a durable paintable surface. Common usage of the terms polyester, epoxy, gel coat, etc apply to a wide range of products and their uses. Thus there needs to be some tolerance for those of us that misuse the terminology in ordinary conversation. Back to the problem at hand, when the paint was removed back in the '80s, was there any difference in the surface texture of the door affected compared to other areas on the car? Were there any dry "hairs" exposed? If so, this would be what I was talking about. Either when the gel coat was applied to the plug it was done incorrectly or when the door was worked for final fit and finish, the gel coat was sanded away before painting. Another possible cause, the GRP panels are pourous, and liquid materials can transfer from one side to the other. As an example, on my '71 coupe - the hood had been damaged slightly on the bottom side by the (you guessed it) air cleaner wing nut. Of course on top the dreaded spiderweb cracking appeared. Thinking that the cracking was caused when the hood was closed on the wing nut, I proceeded to sand out the paint and shoot with fresh color. Looked great for a while, then the spiderweb cracking returned. After fuming and fretting I learned that the GRP is pourous, the cracking was caused by paint lifting, oil from the engine compartment was passing through the hood panel and lifting the paint on top. Sealing the hood on the bottom was pointless, because by now the hood was an oil soaked sponge. I had to replace the hood to solve the problem. |
what color was this gel coat ?
i'm still waiting for the color of this gel coat.
What it all boils down to is the flexing of the body in the normal driving. Glass has to give and take and depending on the thickness of the paint in different areas of the body, it will crack.
Listen to Shine - He obviously knows more than me.
still waiting for the color of the gel coat .
| two tone paint question | makaveli200369 | Body - Exterior | 1 | 05-11-2009 02:36 PM |
| fng paint question. | oldguy829 | Body - Exterior | 1 | 09-17-2008 06:16 PM |
| Paint repair of roughly 3"x3" on a fiberglass bumper | killerformula | Body - Exterior | 2 | 01-11-2008 04:12 PM |
| question about type of paint maaco uses | project66 | Body - Exterior | 7 | 10-24-2004 07:33 PM |
| Primer and Paint on Fiberglass? | Biggarmike | Body - Exterior | 10 | 01-11-2003 05:45 AM |
