Question about pressure switches - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-28-2012, 08:45 PM
rusthater89's Avatar
I bought a new pressure switch for my air compressor. i installed it, got done connecting the wires and such and then I realize that it has no unloader valve. I haven't ran the compressor for any more than about 5 seconds, just enough to make sure the new switch was wired ok.
Is this ok that it has no unloader valve? Am I gonna have problems when I try to primer some parts tomorrow morning?
Old 06-28-2012, 10:55 PM
S10 Racer's Avatar
http://www.warsprints.com
The unloader valve releases any air pressure that is on the piston. Without it, the motor may not start or has a hard time starting or it could pull excessive amps and trip a breaker. You could try and see what it will do but you will have to build maximum air until the motor shuts off, then bleed enough air for the motor to restart.
Old 06-29-2012, 07:44 AM
How would I install a separate unloader valve?
3 oil pressure switches? staleg Engine 7 05-26-2011 06:46 AM
pressure switches or ...? hugger Transmission - Rearend 3 06-23-2007 09:52 PM
new switches... stratt134 Electrical 3 06-02-2006 12:00 AM
Switches Silver_Camaro Electrical 2 06-29-2003 03:41 PM
Wiring Switches!!? corvtsumr Electrical 2 09-11-2002 05:42 PM
