Question about priming over body work - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-23-2012, 09:55 PM
I finished painting my doors, fenders, & bumpers.
All that is left is to spray my quarters & hood, On one of my quarters there are 6 small dings in about a 1 by 2 foot cube. I plan to sand the dents down with 80 grit then apply my filler. My question is can I just spot prime this cubicle area then block that & paint the whole panel? Or is it a must I prime the whole area?
The existing finish is in good condition so If I can avoid having to prime the whole thing since it goes all the way to the front pillar I'd like too.
What do you think?
Car is a faded black, I'm using Single stage Urethane *jet black*, Primer is a high build urethane surfacer *grey*
Old 06-24-2012, 06:02 AM
deadbodyman's Avatar
Wiki Edits: 11
The primer is to seal the filler and fill the scratches ,so its not needed and is actually a waste of material and time (sanding) to prime the whole panel..since the old paint is black and your primer will most likely be grey just give the primer spots a light coat of paint before you paint the whole thing...If you do this it really dosent matter what color primer you use...
67 chevelle body work question Chevelle427Rat Body - Exterior 17 03-05-2011 06:32 AM
Got a question about Body work HELP pat63chevy Body - Exterior 14 09-24-2007 11:11 AM
body work question Vortech 4.3 Body - Exterior 1 06-03-2007 06:01 AM
Question about Corvette body work. GMW Body - Exterior 2 03-26-2006 09:32 AM
Body work question for ya! clutter_1968GTO Body - Exterior 13 06-03-2003 04:23 PM
