question about protecting backside of weld - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 06-24-2012, 10:10 PM
No, LOL, I just have a vivid imagination.
  #17 (permalink)
Old 06-25-2012, 05:18 PM
1971BB427's Avatar
A friend showed me a trick that I've used for years to get to those hard to reach places. Take the nozzle and tip off a can of brake cleaner and install it on your favorite can of Rustoleum or whatever paint you want to use to seal the hidden places. Then get in as far as you can and start spraying. It goes on very wet and really shoots a heavy fog, so be prepared, but it gets into places you'd never reach and is easy to direct the spray. I've even used small hose to connect two nozzles end to end to reach really hard deep spots.
When I was painting the undercarriage, floorpans, and frame on my last project I used this method to get into tight areas, then did the rest with my normal spray gun and even a brush on some. Really works great!
  #18 (permalink)
Old 06-25-2012, 11:18 PM
Cleangreen68's Avatar
man some great stories here. Not that I look fwd to it, but I'm sure ill end up having some stories myself in due time.
Great advice and ideas guys, this helps out alot thanks!
Backside of motorcycle plastics 96p993 Body - Exterior 4 12-28-2010 10:38 AM
U Weld Em Motor Mount Question psatchwill Engine 6 08-08-2010 03:32 PM
painting the backside of fenders, hoods, tail-gate, etc. Custom95Z Body - Exterior 1 07-26-2007 10:29 AM
Boxing frame, weld it all or skip weld it? LiftFlat Suspension - Brakes - Steering 3 11-29-2004 06:55 PM
Behind weld question 1969chevyguy Body - Exterior 2 11-10-2003 02:13 PM
