Question about the rear end and suspension. - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-11-2006, 12:46 PM
rayzorsharp's Avatar
I am very green to hot rodding, I have a 47 dodge, it has skinny tires on it p18575r14. the tires are only 4 inches from the frame itself what are my options as far as getting thicker meats on the back end? any suggestions are appreciated. Thanx!
Old 07-11-2006, 03:41 PM
Most custom wheel companies make rims with special offsets ...
I usually make my own ... I take the center out of one rim and can put it in another ( usually a wider rim ) ... indicate it in on a lathe and weld it up ... Custom Offset ...
What style of rim do you want and what is your wheel pattern ... ( No ... I am not offering to make, sell or give you a rim ) ... Just need to know so I can point you in the right direction ..
Deuce ..
Old 07-11-2006, 05:28 PM
Hey Deuce, I dont like to impose on people the thought of you making or giving me rims never crossed my mind. (although Im sure you make cool wheels) but I am eager to learn and try to do this car on my own so if someone can offer me advice and I can do it the right way thats the route I go. my wheel lug pattern is 5 lug @ 4.5" I think I measured correctly. what do ya think? thanx!
Old 07-11-2006, 07:18 PM
Hotrodders.com has a strict policy against advertising in the tech forums ... SO I did not want members to think I was trying to SELL you a set ...
If you can weld and have access to a lathe ... it is easy.
I use the inner rim with the wheel pattern I need. I then find a rim ... usually wider than what I started with ... and remove the inner rim ... being careful NOT to damage the outer part of the rim .
Or you can buy the outers new ...
I then bolt the wheel center to a axle with the same wheel pattern and put the axle between centers on the lathe
Check for excessive run out ...
Then I install the wheel shell on the center ( after taking it out of the lathe ) and tap it as straight as I can and return the axle to between centers. I make the offset ... as close to being where I want it ... as possible and then I slowly turn the rim/shell/axle by hand and look for run out. Once I get it to fairly close ( by sight ) I use a dial indicator ... to indicate the shell as true as possible.
Once I am satisfied it is as true as I can get it .. I spot weld the rim to the shell ... ( be careful NOT to get any welding splatter on the lathe ... I cover the travels up real good .. ) I then recheck for true .. with the dial indicator ... and weld some more ... jumping from one side to the other and letting things cool ... so as to not draw the rim out of round or out of true. I try and not get the wheel out of balance by too much weld in any one area ...
Or YOU ... can just buy them already done ... they make them just about any way you want ... I am just old school and try to do whatever I can ... cause I CAN ... and it's a HOBBY ... not a job ...
Deuce ...
http://www.wheelvintiques.com/
Old 07-11-2006, 07:30 PM
thats pretty cool deuce, and we do have a machine shop with a lathe.( I work in the manufacturing field).
this is a saver.... GM build codes TooMany2count General Rodding Tech 24 11-23-2009 09:36 AM
Help...rear suspension design questions FrankR Suspension - Brakes - Steering 1 06-02-2006 07:50 PM
Rear suspension swap question. almega Suspension - Brakes - Steering 1 06-05-2005 09:52 AM
Chevy 1500 Rear Suspension Adjustment after lowering jpd37 Suspension - Brakes - Steering 10 05-31-2005 05:36 AM
n00b Rear End Question Walmart Security Transmission - Rearend 3 11-05-2002 07:05 AM
