A question about a rebuild
What options do I have if I do not want to go with a new bottom end on a 78 350? Would I have to get the whole assembly balanced if I just reringed it? I called a performance shop close to home and they said theyed recondition my rods for 125 and balance it for 200. I can't remember what he said boring it would be. He said between 400 and 500 I believe. He said it needed to be torque sleeved. Is this true? I'm guessing it is. Theres another shop close to home and they said 20 a cylinder but they do theirs by hand. I would of course rather not go with a bottom end replacement till next winter really. What are my options? I'm really just lookin to freshen it up before summer hits. thanks guys in advance for your suggestions.
So your saying I could put new pistons in and be fine without the balancing. If I went to a lil higher compression piston would it matter then? I mean thats great news. Alls I'm looking to do right now is clean it up and put a new set of gaskets and bolt to hold it tigether nicely. Thanks again.
Balancing should not be an issue, but you should check yor bearing clearances...
The new pistons should have weight info with them, but your current pistons may be an unknown weight. If you don't have access to a scale, you can take a piston (and pin) down to the post office and use their digital scale, which claims to be accurate to 1/10 ounce. Multiply the weight in ounces by 28.35, and that's the weight in grams. Take a couple of paper towels with you to wipe the scale off with.
| Rebuild Question | rehjr0219 | Engine | 2 | 05-17-2004 06:36 PM |
| Hotrodders Guidelines -- READ ME | Jon | Hotrodders Site Suggestions and Help | 0 | 06-14-2003 05:07 PM |
| Hotrodders Guidelines -- READ ME | Jon | Suspension - Brakes - Steering | 0 | 06-14-2003 05:03 PM |
