question about respirators? - Page 3 - Hot Rod Forum : Hotrodders Bulletin Board
  #31 (permalink)
Old 09-14-2005, 09:58 PM
FORD 2DR's Avatar
Respirators
Originally Posted by gofast51
Great link good info thanks!!!
It is much easier to have the best equipment than to replace your best painters
  #32 (permalink)
Old 09-14-2005, 10:37 PM
grouch's Avatar
Last wiki edit: How to document your project
Last journal entry: 1949 Olds -- Rotisserie, pt. 9
Wiki Edits: 2
Originally Posted by Bee4Me
I call it a POS excuse for an operating system.
Tear away's are a MUST with a paint hood or full mask for that mater.
Paint itself isn't so bad but clear is a completly different story.
It will coat quickly and you need a new "windshield" almost after each coat when doing a complete or large panel. The overspray sticks to it like the glue it is.
The fact that I didn't even think about the overspray ruining a new hood should tell you how much painting I've done. Usually I don't want to hear from a vendor except an order confirmation and the goods. This time I was glad the guy took notice and pointed out the need for those lens protectors. They are a whole lot cheaper than replacing the hood.
  #33 (permalink)
Old 10-22-2005, 10:17 AM
grouch's Avatar
Wiki Edits: 2
Originally Posted by firechicken383
grouch, what all options did you get with yours?
You'll have to let us know some product feedback when you use it.
You asked for it.
I just sprayed a car hood with some epoxy (and made a mess of it first use of HVLP. The epoxy contains no isocyanates but as soon as I popped the top on the can and the fumes hit, I flipped the switch on my new Neoterik system and put the safety hood on. I didn't smell the fumes again until I removed the safety hood after painting.
The system came with a small pump about the size of a football, 50 ft. of rugged-looking hose, a hose connector on a shoulder strap, the vinyl safety hood, face mask and more flexible hose to connect the hood to the strapped connector. The pump inlet has a HEPA particle filter. Don't forget to order lens protectors for the face mask.
The hood has an odor that's a mix between wintergreen and that sickly fresh plastic smell. Time and use make it go away. The lens protectors I got (after a reminder from Len at autobodystore.com) were crystal clear but the face mask for the hood is slightly foggy. Better visibility would top my wish list. The mask attaches to the hood by way of velcro or hook and loop.
The supply hose is fairly stiff but didn't cause any troubles while painting. This was my first use of an HVLP gun, first use of epoxy and first use of the Neoterik air supply system. The only distraction the air supply system caused was when I backtracked once around the hood and the hose came up in a loop. I just gave a little flip of the hip and it fell over away from the car. The shoulder strap held the hose connector just below the small of my back, on one side, and kept the supply hose out of the way the rest of the time.
My garage is 40 feet long. I had an exhaust fan set up in one end and the pump was about 20 feet away from my work, at the other end. I ran the supply hose down on the floor along one side of the car for the length of the car hood, looped it back around the front and down the other side for the length of the car hood. I don't think the hose would have been a problem if I were painting the entire car.
Bottom line: I'm glad I bought it. Shortcoming: visibility. Advantages over respirators: no short-life filters, no shaving my hermit's beard to get a seal, no absorbtion of fumes through eyes and skin.
  #34 (permalink)
Old 10-22-2005, 08:45 PM
I got the same one as you did grouch and painted a complete car while using it. It takes about 5 minutes to get used to and I did a good job IMO, it didn't bother me like I thought it would. My lens was crystal clear and I ordered the lens protectors. I bought mine off ebay, got a really good deal on a never used one. I'm very happy with mine and glad I got it.
  #35 (permalink)
Old 10-22-2005, 10:39 PM
troy-curt's Avatar
Shop Owner And Troll Hunter
I'm glad to see you guys starting to use some good protection.
I've been spraying and grinding paint for 50 years, 6 months ago I had been bragging on how healthy I was at 67, had not been to a Dr. for 30 years, healthy as a horse. In Feb. this year I shot a BC/CC job, that night I went to the Emg. room at the local hospital. Diagnosis...COPD...I've always used the best carbon canister filter I could get. Now I'm dragging a h2o hose every where I go. No more painting for me.
Every one should use a full air supplied suit when around paint!!
Troy
If you don't make mistakes. your not doing anything.
69 SS/RS full custom Camaro 98 ISCA Grand Champion
69 SS/RS BB Camaro wifes driver
66 Elcamino 350/all dz parts,ac,windows,loaded,my driver
69 SS Chevelle BB conv.fresh frame off
26 T sedan street rod
  #36 (permalink)
Old 10-23-2005, 06:30 AM
shine's Avatar
SPI Thug
Last journal entry: some progress
sorry to hear that troy, wish you the best. this is one reason i'm a little *****y about home jobs. i worry that guys just don't realize how nasty this stuff is. my mentor died at 55 when i was his helper. i was 17. since then i have had a complete checkup every year . scared hell out of me. even while mixing this stuff will kill you. a box fan in the window is not an exhaust. it's just not worth it. do your own prep and get someone to shoot it. i'll be 55 this year so my butt's a little puckered. be careful guys.
383 stroker 73monte Engine 13 05-11-2016 11:17 AM
Ignotion Set-ups Native Gearhead Engine 8 11-29-2003 01:20 PM
Hotrodders Guidelines -- READ ME Jon Hotrodders' Lounge 0 06-14-2003 05:08 PM
Hotrodders Guidelines -- READ ME Jon Hotrodders Site Suggestions and Help 0 06-14-2003 05:07 PM
