We're winning the case!
Hotrodders Bulletin Board > Tech Help > Suspension - Brakes - Steering
  #1
Old 07-04-2009, 06:51 PM
STATUTORY GRAPE STATUTORY GRAPE is offline
Question About Rotted Frame.....
I found a mid eighties Monte Carlo that's in decent shape but the frame is rotted through in a couple of spots. Is there any fixing to this, or would the whole frame need to be replaced? It's a full frame car but it's rotted behind the front passenger tire about eight inches long going towards the rear of the car and wide enough to put all my fingers in. It's also rotted out behind the rear driver tire just behind the rear axle. Possibly more places also but I can't see under the car very well. Would this car be better off being sent to salvage? What would it take to save this car
Old 07-04-2009, 06:59 PM
RSM's Avatar
RSM RSM is offline
rust
Well, unless your planning on a total resto or even a partial a frame replacement is a lot of work. If you have any rust holes at all the frame should be junked. Thats an accident waiting to happen repairng something like that but it's your call. If you have any reputable shops around you, take it to them and get a professional opinion. Good luck.
Old 07-04-2009, 07:17 PM
ericnova72 ericnova72 is offline
More for Less Racer
This can be repaired quite easily with the body off the frame, or pick up another frame, repair it, and swap the body over. You will need to look the underside, floorpans, etc. of the body over very carefully because rarely is the frame this rotten and the body still be saveable with these metric chassis cars.
Take an ice pick or a small screwdriver and poke any questionable spots probing for soft areas. Undercoating and carpet will hide a lot of ills. I could almost guarantee that this car is a lot worse underneath, if the frame is rotten, than the upper half of the body looks.
Old 07-04-2009, 11:06 PM
techinspector1's Avatar
techinspector1 techinspector1 is offline
Senior Curmudgeon
techinspector1's barnstar
Wiki editor
Last wiki edit: Threading tips
Wiki Edits: 210
Yep, looking at rust is like looking at an iceberg. You only see 1/10th of it.
Old 07-05-2009, 06:17 PM
Thanks for the advice guys. I think it would be best to just scrap the frame. Are these frames heat treated or could a pro shop weld it without weakening it?
Old 07-05-2009, 06:52 PM
More for Less Racer
Frame is just mild steel, no heat treat, anyone with a welder that knows how to weld could do it.
Old 07-05-2009, 08:09 PM
poncho62's Avatar
poncho62 poncho62 is online now
poncho62's barnstar
Wiki editor
Wiki Edits: 5
These frames rotting is a commo0n problem with them.....There are repair sections available for the rear area, not sure about the front.
Old 07-05-2009, 08:53 PM
cobalt327's Avatar
WFO
cobalt327's barnstar
Wiki editor
Last wiki edit: Chevrolet restoration packets
Wiki Edits: 20
There's (IMHO) not enough return on your investment- unless you have an emotional attachment of some sort- to justify the amount of work, time and money needed to properly resurrect a car as common as the metric Monte Carlo if it's badly rusted.
A better option might be to pass on that one and hold out for a better candidate. In your area this may be hard to find- those salty winters will have taken their toll on anything driven in the snow!
Reply Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
Similar Threads for: "Question About Rotted Frame....."
Help! what frame to put under a chevy 1 1/2 ton truck? Riley Hotrodding Basics 10 02-15-2009 08:15 AM
41 Plymouth Frame question... Tyroma Suspension - Brakes - Steering 12 12-21-2008 08:14 PM
question about a pro street frame alle4901 Suspension - Brakes - Steering 7 10-09-2008 02:47 PM
Frame Mod question johnnymopar General Rodding Tech 18 04-12-2006 06:24 PM
Frame Question. Rubberman2003 Suspension - Brakes - Steering 2 12-03-2003 01:49 PM
