Question about rust ........... - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-14-2007, 09:40 AM
I have heard that in a pinch, you can use a wire brush on a rusty piece of metal to get the flakes off and coat it in motor oil to prevent the rust from spreading until you can paint the surface. The floorboard on my Trans Am has some surface rust, and am thinking about using a paintbrush to coat it with oil until I can get some POR-15 to fix it. Will this work, or is it a waste of time?
Old 05-14-2007, 10:17 AM
Oil inside the car? Not in one of mine! Just wait until you can get the POR-15... you'll have a hard time getting the motor oil out of the rust pits to get a good bond for the POR-15.
Old 05-14-2007, 11:38 AM
POR15 will not "fix" it , it will cover it up and slow it down but it will still be there. Rust is metal that is missing and stopping it is not the same as repairing it. I have heard more than once "if I try to get rid of all the rust (blasting,replacing metal) I won't have anything left!" as if the rust adds something? Rusty metal should be repaired not hidden.
Best way to remove surface rust 49studebaker Body - Exterior 5 10-31-2006 07:30 PM
big rust "problem" with former vinyl top car bullheimer Body - Exterior 3 02-14-2006 12:08 PM
Rust Dissolver versus Rust Convertor? 66GMC Body - Exterior 9 11-06-2005 05:48 PM
phosphoric acid rust converter question zachscc Body - Exterior 1 11-10-2003 04:55 AM
Body work (RUST) Trav Body - Exterior 10 10-06-2003 11:27 AM
