question about rust w/picture - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-05-2006, 08:17 PM
blackjackbender's Avatar
Well im going to be patching some of my fender lip on the rear 1/4 panel in the next few days. there is some surface rust and I was wodnering if that should be cut too or could I run over that with a flap disc and see how it turns out first? I dont want to do extra work if I dont have too.
Thanks
Ty
Old 04-05-2006, 08:54 PM
Buy a handheld spot blaster and sandblast this area, I think it'll clean up fine. Replace the lower section. Coat all the seams from the inside with a rustpreventative spray like 3M's rustfighter or cosmoline. Epoxy prime the exterior when you get the metal completely sanded with 80 grit and clean. Bodyfiller can be applied over the epoxy, scuff the epoxy first if it's been curing for more than one day.
Old 04-05-2006, 09:14 PM
Thanks will pick one of those up in the next few days. Trying to get this thing completely done by june 16th and it looks like this now, gotta tune engine, finish suspension, and do body work
secrets of surface rust removal revealed Randy Ferguson Body - Exterior 178 09-24-2011 09:36 AM
What to spray on sandblasted steel to kill rust STATUTORY GRAPE Body - Exterior 64 08-26-2007 03:28 PM
big rust "problem" with former vinyl top car bullheimer Body - Exterior 3 02-14-2006 12:08 PM
phosphoric acid rust converter question zachscc Body - Exterior 1 11-10-2003 04:55 AM
Body work (RUST) Trav Body - Exterior 10 10-06-2003 11:27 AM
