question about sleeving - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-03-2006, 11:42 PM
dboyett38666's Avatar
I have a 400 block that is 40 and want go 60 does anyone know how much it cost to get all 8 cylinders done?
Old 03-04-2006, 01:34 AM
GoneNova/406's Avatar
you may be able to email this place and get an idea.from what i have read it's ehttp://www.darton-international.com/xpensive but makes your block stronger doing all of them.
Old 03-04-2006, 06:20 AM
6426yy's Avatar
Is there something wrong with the cylinders? I wouldn't bore it unless absolutely necessary. 400 blocks are getting pretty scarce and if you don't need to take it over now then you can save it for the next rebuild. As for the cost here where I live it's $10 a hole plus dip and mag fees. $25 to $35 each I can't remember.
Old 03-04-2006, 07:15 AM
King of my Man-cave.
I just read your other two posts. I deleted my answer 'cause it's rude to make multiple post on one subject.
tom
Old 03-04-2006, 08:24 AM
Infomaniac's Avatar
Twin Turbo Drag Boat
Last journal entry: Random In Progress Shots
In my shop by the time we clean it, mag check it, sleeve all 8, deck, cam bearings and freeze plug it will run you almost $700.00
Old 03-04-2006, 03:43 PM
Thats not as bad as I thought.I probably am going to have it sleeved.Thanks
Old 03-04-2006, 04:46 PM
Jmark's Avatar
just bore it 60 and use it.
Old 03-04-2006, 05:09 PM
a call from the machine shop He tried. Sounds as if though the machine shop error'd.
Old 03-04-2006, 09:25 PM
tom
I dont think it is rude at all I think its rude for you to say it is rude for me to post 2 questions to try to get a response on this info,and i didn't intend to do that but thanks foe your info
Hotrodders Guidelines -- READ ME Jon Hotrodders Site Suggestions and Help 0 06-14-2003 05:07 PM
Hotrodders Guidelines -- READ ME Jon Suspension - Brakes - Steering 0 06-14-2003 05:03 PM
Hotrodders Guidelines -- READ ME Jon Electrical 0 06-14-2003 05:01 PM
Hotrodders Guidelines -- READ ME Jon Body - Exterior 0 06-14-2003 05:00 PM
